DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Refilling microbore system
This topic originated from the How to page called Removing a radiator
Click here to return to the page called Removing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
supersmig
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 30, 2006 5:28 am    Post Subject:
Reply with quote Thanks
Could you please tell me how you refill this type of system as my knowledge only extends to conventional systems
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
chrishutt
from St. Pierre and Miquelon
Thanked: 2 times
PostPosted: Thu Mar 30, 2006 6:00 am    Post Subject:
If you mean a sealed system (with pressure gauge but no header tank), look in the FAQ topic near the top of the topic index for details on filling loops. The fact that your system is microbore is not relevant to whether it's open (conventional?) or sealed.
__________________
Let's face FAQs.
Back to top
 Alert Moderators
supersmig
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 31, 2006 8:46 am    Post Subject:
Refilling Microbore System
Thanks for your quick reply.
It was the last line (never assume anything) that led me to recheck everything.
The repair to the system was to replace the leaking hot water cylinder.
i assumed that the cylinder for replacement was an indirect one as the system is pump fed hot water. I have looked at the old cylinder again and found this to be a not so common, Primatic Cylinder.
Problem solved as to why i cant fill the system.
What i would like to know now please is;
When Ihave fitted a new expansion tank in the loft can i tee the new fill and expansion pipes into the indirect coil conections on the cylinder (This is where the central heating filled on the Primatic) or has it got to be somewhere different.
The system is very basic, you can only have hot water and central heating. The heating is mostly microbore, the rest is conventional.
Everything on the system is pump fed so the heating coil in the cylinder is virtually another radiator.
What a mess.
Back to top
 Alert Moderators
chrishutt
Thanked: 2 times
PostPosted: Fri Mar 31, 2006 4:54 pm    Post Subject:
If you are replacing the cylinder it might be worth thinking about adding controls so that you can use the system more efficiently. Have a look at the Honeywell site - you could use a Y or S Plan.
On a fully pumped system the new header tank would have its feed and vent pipe connections close together on the flow pipe with no valves of any sort between the boiler flow connection and the vent connection.
__________________
Let's face FAQs.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
refilling microbore radiator 2 360 Mon Oct 16, 2006 8:34 pm
Refilling central heating system 2 740 Thu Oct 05, 2006 10:23 am
Refilling Central Heating System 7 640 Sun Jan 04, 2009 8:54 pm
Vaillant Combi wont fire up after refilling CH system 13 400 Sat Dec 20, 2008 7:46 pm
Refilling central heating system floor standing boiler 18 440 Mon Jan 05, 2009 6:16 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
