Mixer tap with pull out head
31 Mar 2006
West Midlands
We have purchased a mixer tap for our new kitchen . It has hot and cold water supply pipes as usual but am not sure where the 3rd pipe should be fitted (connecting the pull out head through the middle of the tap).
Regards,
John.
is it for a filter or something like that
do you have the installation instructions it must say on them?
Not a filter - pull out tap head for rinsing stuff, retracts back into place as normal tap. No instructions in box.
Does this not come already connected to the body of the tap?. When you pull it out does it come completely away from the body?
What is make of tap?
This pipe runs through the centre of the tap. When pulled out end not connected to anything at the moment. It is called Denver pull out kitchen mixer tap and supplier is tapsuk.com
Whats on the end of the tube connected to the rinsehead? Is this tube stretchy? If not how is the tube retracted into the swanneck?
I'm grasping at straws here but I'm sure somebody on here will have experience of these.
