DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Fitters stepped on roof, now leaking
This topic originated from the How to page called Tiled Roof
Click here to return to the page called Tiled Roof.
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering
  View previous topic :: View next topic
Author Message
Erstwhile
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 03, 2006 10:55 am    Post Subject:
Reply with quote Thanks
Window fitters have stood on the low roof over the front of the house, disturbing several tiles in the process. Whilst no tiles have been cracked or broken, there are a couple of places where several tiles noticably sag and do not fit together snugly anymore. This has let in a small amount of water, which has dripped down an inside wall causing discolouration.
The damage occured early last week, but we have had a lot of rain since - should I be expecting a lot of damage? And what might need fixing?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
masona
from United Kingdom
Thanked: 7 times
PostPosted: Mon Apr 03, 2006 5:35 pm    Post Subject:
Best to have a word with the window fitters to put it right.
__________________
Always judge a man by the way he treats someone who is of no use to him
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 71 times
PostPosted: Mon Apr 03, 2006 7:19 pm    Post Subject:
i guess it would be a good time to get some decent underslaters felt fitted then eh?
Back to top
 Alert Moderators
Erstwhile
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 03, 2006 7:24 pm    Post Subject:
Ideally yes, this is exactly what I'd do. But they've caused this damage whilst repairing some damage they did when they originally installed the new window. I'd rather get them off my property for good and fix this myself in all honesty.
I had a look up close this morning and there doesn't appear to be any serious damage. Just a couple of spots (about 2ft square each) where weight has been put against the tiles and caused something beneath to break or sag. The rest of the roof is absolutely fine - still straight and level with no signs of damage or sagging.
Any ideas what I might need to fix? I'm thinking (hoping!) all I'll need to do is lift the few tiles in the affected areas and then shore them up somehow. But I've absolutely no experience with this sort of thing, so I'm clutching at straws here...
Back to top
 Alert Moderators
joe-90
from United Kingdom
Thanked: 57 times
PostPosted: Mon Apr 03, 2006 8:36 pm    Post Subject:
Tiles are fitted on wooden battens that keep them straight. If one is broken it will sag. Simply remove the tiles using wedges so you can unhook them and replace the timber battens.
It's not a big job.
Do a Google and you'll find a diagram.
joe
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 71 times
PostPosted: Mon Apr 03, 2006 8:46 pm    Post Subject:
if the weight of the roofers footfall has damaged the roofing battens, then im guessing the lathes are quite thin and the roof quite old. yes it will be easy to repair and invisible, but the roof sounds quite vulnerable to me.
Back to top
 Alert Moderators
Erstwhile
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 03, 2006 10:13 pm    Post Subject:
Well, the house is only about 15 years old so I hope not! At least it sounds like it shouldn't be too difficult a job at least (although I've not found any diagrams yet).
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Tue Apr 04, 2006 8:45 am    Post Subject:
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering All times are GMT
Page 1 of 1
Jump to:
Does lead flashing have to be stepped? 4 1400 Wed Apr 16, 2008 2:34 pm
leaking roof 14 840 Wed Jul 11, 2007 11:21 am
FLAT ROOF LEAKING 3 760 Thu Jul 12, 2007 7:08 pm
Please help - leaking roof - polyurethene foam spray 2 960 Mon May 21, 2007 11:04 am
Help Please!!!!! My new garage roof leaking 4 460 Wed May 16, 2007 9:00 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
