DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Combined washing m/c and sink waste
This topic originated from the How to page called Plumbing in kitchen appliances
Click here to return to the page called Plumbing in kitchen appliances.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Shropshire_Andy
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 03, 2006 1:11 pm    Post Subject:
Reply with quote Thanks
In our last house the washing machine drained into its own standpipe. In the current house (rented, so no chance of changing things) there is a side-tube just above the bottom of the 'u'-bend under the kitchen sink drain.
The waste pipe hooks up to it just fine, but I'm a little concerned about water feeding back into the washing machine (potentially full of clean washing) if, for example, we were to pour a lot of dirty water down the sink.
Because of space-constraints in the cupboard under the sink, there\\\'s no way I can get the highest point of the waste pipe any higher than the underside of the sink.
Is there some kind of non-return valve which can be fitted in-line with the waste pipe to ensure that water only flows out of the washing machine? I've seen "anti-syphon" devices, but I'm not sure that's exactly what I need.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Gasguru
from United Kingdom
Thanked: 17 times
PostPosted: Mon Apr 03, 2006 1:53 pm    Post Subject:
Anti - syphon valves are designed for excessivly long lenghts of waste hose (stops all the water being syphoned out of washing machine during a partial drain)
Just extend hose enough to tie up to worktop level and prevent sink water backflowing.
Go to a good plumbers merchant - get a coupling piece, lenght of corrugated hose and the rubber coupling for each end (these screw into the corrugated hose - seal with silicon)
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Mon Apr 03, 2006 2:37 pm    Post Subject:
Re: Combined washing m/c and sink waste
Shropshire_Andy wrote:
Is there some kind of non-return valve which can be fitted in-line with the waste pipe to ensure that water only flows out of the washing machine? .
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
combined dishwasher/washing machine outlet 5 620 Thu Jan 03, 2008 9:52 am
Combined Dishwasher and Washing Machine Outlet Problem!!! 3 6780 Thu Nov 04, 2004 12:23 pm
combined washing machine and diswasher pipework 2 600 Tue Sep 04, 2007 12:44 pm
Wisdom of combined waste for kitchen sink and appliances? 5 4100 Tue Aug 29, 2006 10:00 am
combined waste pipe problem 2 4420 Fri Oct 14, 2005 8:42 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
