sLIGHT BUZZING FROM KITCHEN TAPS
4 Apr 2006
Newcastle upon Tyne
Just had a kitchen newly installed - i plumbed in the sink- no leaks! But the taps give a very small electric shock when touched! Not life threathening but noticable!
Question ; Do they just need earthing?
Can i just earth it to the rear of a 13 amp plug? Using earthing wire of course?
JDLD
Is your main bonding in place?
What earthing system do you have? TT? TNS? TNC-S?
How is the kitchen sink fed? copper or plastic pipe?
What is the floor covering in the kitchen?
Sorry bit of a novice here - main bonding , how can i check that?
Floor is good old 1980's wood board(cheap and squeaks a lot!)
What earthing system do you have? TT? TNS? TNC-S? - no idea(honesty always works!) mid 1980's house - conventional build.
Copper pipe to the taps(no plastic in the house)
Forgot to mention - basin in a new place in kitchen(old utility) but using pipes already in place for a washing machine
For earthing system, (TNS TNCS TT), look in the reference section.
Have you done any electrical work in this kitchen? Probably best to enlist the services of a qualified electrician, as if it requires ANY electrical work, it will need certification on completion and I doubt from your previous posts, that you are knowledgeable on the subject, enough to complete them.
thanks for the replies so far. Would have liked some advice rather than told what i can or cannot do! Sorry for that one - I am NOT trying to be insulting. I am just asking for help on the easiest way of earthing the taps until i can get a real big boy electrician in! That way her indoors can use the tap without using a cloth to insulate herself!
thanks
The Easiest way without disturbing anything your fitter may have done wrong (EVIDENCE!!!!!) is to connect a lead from the pipework to the earth terminal of a normal plug and plug it in!
I would start by turning your houses circuits off one by one until you work out which one is putting current onto your sink (unless it's some kind of static electricity!). Leave this circuit off until you can get an Electrician to look at the problem. Do not try to earth the sink etc as you may put yourself in more danger!
Yes, bonding the sink/pipes is no longer recommended as it may introduce parallel earth paths.
