Hot water cutting out the central heating
5 Apr 2006
Oxford
When I turn my central heating on by pressing the button on the programmer everything is fine, If I then press the button for heating the domestic hot water the pump and boiler switch off, the lights stay on at the programmer if I then turn off the Hot water the pump and boiler kicks in again to heat the rads..... can anyone shed any light?
only stops when both ch & hw on ?
wot type of diverter valve have you , suspect a 3 port .
wired up wrong , hw off signal not present ?
yep the ch is on, then turn on hw, then it shuts down until hw is turned off then ch comes on again
Yep a 3 port honeywell with potterton programmer
Either the system is wired up wrongly or the diverter valve has failed.
Has it been fiddled with or did it just stop working?
Tony
Well, 2 weeks ago I cleaned the system and added Fernox, when draining I put the 3 port valve on manual...thats about it. I suspect the 3 port valve micro switch or something like that.
Fixed it!, it was the stat on the hot water cylinder, happened to have a spare one in the loft.
