One cold upstairs radiator
Status
Not open for further replies.
11 Dec 2003
I have a radiator that has recently stopped working. I have read the other comments and here is my own situation:
1. the radiator is cold
2. the inlet and outlet pipes are cold
3. it has a thermostatic valve
4. all the other radiators in the house are hot
Am I right in thinking this implies there is a blockage in the pipe between the boiler and the radiator?
What is the best way of finding out if this is true?
Thanks for your help.
Ruth :)
Try taking the white plastic thermostat bit off the thermostatic valve you should see a brass coloured pin. Make sure this moves up and down freely. Sometimes they stick closed.
I have had same syptoms and that was the solution gentle(!) tapping with a hammer freed the pin now all is fine
Regards
Chris
Could be an air lock. Try turning OFF most or all of the other rads - that will push it out so you can bleed it from the radiator.
Status
