Finally got round to taking the top off, is the thermostat the round thing with 2 wires going to it located between the blower motor and the heating element. The wires had something like black soot on them so is this likely to be the problem? cant get a replacement thermostat
Use a multimeter, take the wires off the stat and check for continuity through the stat. If it's open circuit you need a new stat, available from a local repair shop (they can order if not in stock). If the stat is ok do the same checks on the element.
