jemima
Joined: 06 Apr 2006 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Thu Apr 06, 2006 4:46 pm Post Subject: upstairs lights not working |
Following work on a new bathroom,the bulider has plastered over an old shaver socket, but not before blowing the fuse on the consumer unit for the upstairs lights. We have a consumer unit from the 70\\\'s which has cartridge fuses. Have identified the blown fuse wire and replaced, but lights still do not work. Have switched the cartridge fuse for the upstairs lights with the one for the downstairs lights and the upstairs lights still do not work . Although the downstairs lights will work with the fuse with the replaced fuse wire.
Any ideas on why the upstairs lights still do not work.
Have tried to replace bulb with a new bulb in case the bulb blew.
Exuse the ignorance - very novice DIYer.
Many thanks |
Adam_151
Joined: 17 Jun 2004 Posts: 4538 Location: United Kingdom Thanked: 10 times
Posted: Thu Apr 06, 2006 4:54 pm Post Subject: |
How did you change the wire on a cartridge fuse?
In a holder that looks like this?
or did you mean a Re-wireable fuse
How did the builder remove the socket, I hope he didn't just take it away and plaster over the live wires (correct procedure is to disconnect the feed cable at the other end, and cut as much of the redundant cable out as possible, then plaster)
Its possible that the fault current when the builder caused a fault either took out the fuse in an FCU (http://www.tlc-direct.co.uk/Images/Products/size_2/CM2365.JPG) that could possibly exist on your lighting circuit, or blew apart a poor connection
Oh and you did replace with the right fusewire didn't you?... white spots = 5 Amp  |
jemima
Posted: Thu Apr 06, 2006 5:00 pm Post Subject: |
Thanks for the quick reply
It was a rewirable fuse - the 3rd option in your post.
I did use the correct fuse wire.
I was not at home when he took of the old socket & can not get old of him on the phone to see what he did.
Where would I find an FCU in the circuit.
If it blew apart a poor connection, how can I check
Many thanks |
Adam_151
Posted: Thu Apr 06, 2006 5:25 pm Post Subject: |
| jemima wrote: |
If it stopping all the lights working, between the fusebox and the first light on the circuit, as to physically, I don't really know, its actually quite unlikely that there is one, but its possible
| Quote: |
Many thanks |
If you can get into the attic, try and find which light is first on the circuit, and check any connections between the first light and the CU if you can
Its also possible that the shaver socket was the first thing on the circuit, and the circuit is open becuase its been removed, try and get above the place where it was, and see if you can find out how many wires go down to it, changes are, if there are two, you'll need to cut them and join them in a junction box, it could be more difficult if the feed was into the socket from below and went up and continued onto the lighting circuit |
