Joined: 06 Apr 2006 Posts: 9 Location: United Kingdom Thanked: 0 times
Posted: Thu Apr 06, 2006 8:38 pm Post Subject:
do I need to drain the central heating to replace a radiator
I am putting in a new towel rail radiator where there was once a normal radiator, at the moment there are the two lengths of pipe that connected to the old radiator valves with stop ends on, there is also the drain valve (hose pipe) after this radiator, the c/h is operating at the moment, do I have to drain all the radiators before I can install the radiator now? also can I use the spped fit pipe and connections in place of copper:?:
Posted: Thu Apr 06, 2006 8:56 pm Post Subject:
MMMM even I knew that! lol what I wanted to know is do I have to drain ALL the system or could I for instance lock off the flow at the radiator before this one in the system? and can I use the plastic push fit conectors into the radiator valves?
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Thu Apr 06, 2006 10:56 pm Post Subject:
1) if you want to reduce the amount of water that you drain out (e.g. it has inhibitor in) then you can close BOTH ends of all the other rads.
2) you might like to use bungs (tapered rubber things that you will find on the plumbing tools shelf) instead of draining down. They really do work. If you have the F&E tank in the loft, you stuff one into the vent pipe that hangs down over the tank, and one into the feed pipe at the bottom of the inside of the tank. this prevents much water coming out provided that you only have one open end at a time (so, cut off one of your stop ends, put a closed valve on it, then do the other.
3) you will find it very difficult to solder wet pipes, even when you think you've got all the water out.
Posted: Fri Apr 07, 2006 6:02 am Post Subject:
How I ended up with stop ends in place of radiator!
Well my sister in law hired the services of a plummer / tiler???? from the local rag to fit her new bathroom suite, he was sacked after 3 weeks and 3 house floods later! he took the rad out and put stop ends on the pipe work!
Now I'm putting it right!
Posted: Fri Apr 07, 2006 6:06 am Post Subject:
How solder would sort it out!
I meant I will have to use copper pipe and cut into the exsisting pipe work with yorkshire fittings if I could not use the plastic connections to the rad valves!
But you have redeemed my faith in plumbing by telling me you CAN buy the fittings in plastic to the valves!
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
