DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Faulty Circuit Breaker?
This topic originated from the How to page called Identifying a faulty circuit
Click here to return to the page called Identifying a faulty circuit.
  View previous topic :: View next topic
Author Message
Breaker Problems
from United States of America
Thanked: 0 times
PostPosted: Tue Apr 11, 2006 6:14 pm    Post Subject:
Reply with quote Thanks
I have been having trouble with my AC unit. Occasionally, the breaker flips and I have to reset it. I have had an AC company come out to look at the unit 5 times now and they still can not pinpoint an AC problem. I am starting to think it is the circuit breaker itself. How can I determine if the breaker is the culprit and needs to be replaced? The AC company is only interested in selling me AC parts. Today they decided that I may be leaking freon!!!! The system cools just fine when it runs and it will run for days without flipping!!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Tue Apr 11, 2006 10:37 pm    Post Subject:
Try posting in the Electrics outside UK!
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Tue Apr 11, 2006 10:53 pm    Post Subject:
If I thought I had a faulty MCB, I'd just fit a new one. SP MCB is about £5 over here.
It's very unusual, though. I've heard the Chinese manufacturers, including counterfeit, can be very poor quality. I've known UK manufacture, such as Crabtree C50, run faultlessly for 40 years.
I wouldn't consider the MCB to be faulty before I'd compared the rating of the MCB with the rating on the AC unit, verified that there was no other load on the circuit, had a look for signs of overheating including damaged cables or rainwater/condensate causing a short.
I might also try a clamp meter to look at the actual current draw and compare to the AC rating; and I'd look up the manufacturer's documentation to see if they recommend a surge-resistant "slow-blow" type C or greater MCB to accommodate start-up surge.
What current does the maker's rating plate on the AC unit say, and what rating and type is your MCB?
What other loads are on the circuit?
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Faulty Earth on lighting circuit 4 400 Thu Sep 07, 2006 8:50 am
Has Faulty Kettle Damaged Electrical Circuit? 3 480 Mon Jun 05, 2006 2:50 pm
Faulty circuit? 24 1060 Sat Aug 05, 2006 9:06 pm
Faulty Circuit While Replacing Light Bulb 21 620 Sat Dec 30, 2006 4:08 pm
faulty ring circuit 4 1860 Fri Apr 06, 2007 7:24 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
