Dishwasher Rumble - Whirlpool ADG 7540
30 Dec 2003
Worcestershire
I've a fitted Whirlpool ADG7540 dishwasher. Of late it has produced a rumbling sound when in its cycle. It's the sort of sound that I would associate with the spin-arms spinning eccentrically (i.e. come loose). However I have had these out and cleaned them through and reseated them OK per the handbook.
Anyone got any ideas ?
Put something into the dishwasher to stop the arms turning. If the noise stops you need new arms. If the noise doesn't stop then you're probably looking at replacing the circulation motor/pump.
My machine makes the same noise and I've found the cause but not the cure. The grey pipe that takes the water out clicks into two sockets behind the spinning arm on the floor of the machine. If it springs loose it rattles during the cycle and doesn't suck the water out properly; you may notice food deposits being left. You can click it in place but mine keeps springing out. Any suggestions how to stop it?
The proper cure is to replace the part it clips into. You could of course use silicon sealant to fix in.
