I hope someone can help me as my local heating engineers don\\\'t seem to have a qlue.
I have a pressure problem with my combi boiler. Basically when the heating is off the pressure gauge falls to zero.
Before I start the heating system I have to repressure the system to 1 Bar, when the heating has been on for a while the pressure continues to climb off the clock (3 bar +).
The pressure safety valve operates at this pressure as it should do, when the heating switches of the pressure falls to 0 Bar in approx 30 mins.
On an occasion that the pressure was at 3 Bar I noticed there was a small amount of water around the schrader valve on the expansion vessel, I also checked the pressure in the expansion vessel with a car tyre gauge and found that I was approx .25 Bar, I repressured the vessel again and this seemed to reduce the rate at which I was loosing pressure from the system when the heating was off.
I have also circulated 500ml of Fernox leak sealer around the system via on of the down stairs rads over a 24 hour period in case there are any small leaks on the system, but I can\\\'t find any.
I have done some detective work of my own and feel that the expansion vessel may be the problem area.
I would appreciate it if someone out there can assist me where my local engineer cannot.
It\\\'s costing me a fortune and getting nowhere.
