DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
central heating
This topic originated from the How to page called Removing a radiator
Click here to return to the page called Removing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
naylor
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 16, 2006 12:09 pm    Post Subject:
central heating
Reply with quote Thanks
just built a two story extention...is it ok to connect to the central heating radiator circiut on the existing upstairs into the new part upstairs then run it down into the new extention downstairs or is it best to go upstairs to upstairs and lower to lower?...does it matter ?..thanks for any replies
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
croydoncorgi
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 16, 2006 12:22 pm    Post Subject:
Have you actually checked what pipe sizes run to where?
How many rads in the new bits?
If you connect the new downstairs rads to the upstairs circuit, you may run out of pipe capacity and / or operating pressure, so no heat will get downstairs.
But most 'conventional' heating systems have the pump upstairs, next to the cylinder anyway. Where's yours?
Also, depending on the size of the house, Building Regs demand separate upstairs and downstairs zones. Even if your (enlarged) house is not that big, it might still be a good idea to zone it.
Back to top
 Alert Moderators
naylor
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 16, 2006 2:25 pm    Post Subject:
thanks for the reply...there two extra rads upstairs and two down stairs all running on 15mm pipes, a new bigger condenser boiler as been fitted to take the bigger output, ive no cylinder everythings just coming of the boiler.
Back to top
 Alert Moderators
croydoncorgi
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 16, 2006 3:12 pm    Post Subject:
Yes - but what boiler is it? Combi? system boiler? where's the pump? what size of pipe are youb planning to connect TO?
Back to top
 Alert Moderators
naylor
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 16, 2006 5:25 pm    Post Subject:
its a combi(potterton performa 30he) i presume the pumps in the boiler?..was just gonna branch off the existing pipe work which is 15mm
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
central heating pipe sizes 10mm to 15mm 4 580 Sat Apr 05, 2008 1:42 pm
Need to run hot water to start central heating 2 260 Sun Apr 06, 2008 11:07 am
No hot water or central heating. 24 520 Thu Apr 03, 2008 11:11 am
Alpha 240P Hot water ok but NO central heating 2 240 Thu Apr 03, 2008 10:16 am
Poor circulation on central heating. 14 800 Wed Apr 02, 2008 12:55 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
