DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
removing a radiator
This topic originated from the How to page called Removing a radiator
Click here to return to the page called Removing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Bevstaxis
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 17, 2006 10:21 am    Post Subject:
removing a radiator
Reply with quote Thanks
we wish to remove a radiator to decorate behind it. mu husband knows how to do this, but the nut is well and truly stuck. Any ideas please? thanks!! icon_confused.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Bahco
from United Kingdom
Thanked: 5 times
PostPosted: Mon Apr 17, 2006 10:25 am    Post Subject:
Drain it and apply heat with a blowlamp or heat gun carefully. icon_biggrin.gif
__________________
85 weeks without smoking!
Back to top
 Alert Moderators
Bevstaxis
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 17, 2006 11:26 am    Post Subject:
Thanks...but how do we drain it if we can't remove it?! We've more or less given up on the idea, as it's eating into our decorating time...but it was worth a try. Thanks for looking.
Back to top
 Alert Moderators
white_dragon
from United Kingdom
Thanked: 0 times
PostPosted: Thu Dec 13, 2007 9:42 pm    Post Subject:
Stuck Nuts
I realise this post is a little delayed but it might help someone looking for an answer.
I had this problem whilst trying to remove a very old rad that was well and truly stuck. WD40 worked for me but any penetrating fluid sprayed around the problem nut and given a few minutes should loosen the gunk. Try tightening the nut gently and loosening it in one movement without bending the pipes (have someone to hold the pipes with another adjustable spanner).
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
REMOVING RADIATOR PERMANENTLY 2 880 Thu Oct 06, 2005 11:40 am
Quick question about removing a radiator 5 220 Sat Jul 12, 2008 12:30 pm
Removing radiator 5 460 Fri Oct 07, 2005 6:51 am
Removing a radiator valve - Help!!!! 4 280 Wed Jun 27, 2007 5:07 pm
Removing radiator - combi boiler 7 620 Thu Oct 13, 2005 6:00 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
