ZANUSSI FJD 1666W NOT RINSING
17 Apr 2006
The machine pre washes fine but as soon as it gets to the rinse cycle it suddenly goes to the drain cycle. I have taken the pressure switches of and checked them all ok. and i have take the drain pump off and that too was ok. But when I took the jet system nozzle pipe off and blew down it I found the pipe was blocked. The recirculating pump was blocked sold with old detergent, I cleaned all the pumps and piepworks and tried the machine again, Still no rinse cycle. I checked the recylce pump with a multimeter and only got 39 ohms (seems very low to me) does anybody know what ohmic value the average askoll pump should read ( i think it should be around 1500-2000 ohms). thank you
Bought a new pump, resistance equals 2k ohms. plugged it in and the fault is still there!!! does anybody know if there is a fuse for this pump located in the washing machine and if so where is it? Thank you
