dk0965
Joined: 18 Apr 2006 Posts: 1 Location: United States of America Thanked: 0 times
Posted: Tue Apr 18, 2006 12:38 am Post Subject: Clogged Outdoor Drain |
I have a set of concrete steps which go from ground level down to the basement; below ground. I have a drain in the lowest point in the base of the steps. I bought the house, but the owner failed to mention that the drain had been clogged for years. Everytime it rains, there is a possibility of a flooded basement. I have tried a plunger, and I tried using a wire hanger like a snake. The wire hangar goes down about a third of a meter and stops. No matter how I twist or push, it stops in the same spot. I cannot see anything obvious obstructing flow. Any thoughts or wisdom would greatly be appreciated. DK0965 |
oilman
Joined: 16 Sep 2003 Posts: 7790 Location: United Kingdom Thanked: 7 times
Posted: Tue Apr 18, 2006 4:58 am Post Subject: |
contact a drain clearing expert. You will not have the appropriate gear, and it might be expensive to have someone do it, but it will be expensive if you do nothing. |
pajacobsen
Joined: 30 May 2006 Posts: 1 Location: United States of America Thanked: 0 times
Posted: Tue May 30, 2006 10:36 pm Post Subject: clogged outdoor drain - help! |
I have precisely the same problem.
Outside of having expensive help come in, how do you break up the clog (it looks like a mix of mortar, pebbles, and concrete)?
Was this problem ever solved? Did you get help from a professional? If so, how was the work done?
Thank you,
Per
please see forum rules 17 & 20 |
Agile
Joined: 26 Jun 2004 Posts: 24304 Location: London, United Kingdom Thanked: 192 times
Posted: Wed May 31, 2006 12:23 am Post Subject: |
We will probably never know!
People are quick to ask for advice but rarely tell us what the problem turned out to be.
If the drain is blocked with concrete and you can get to it you may find that only the surface is solid and there is soft stuff underneath.
In the worst case it may be necessary to cut out and replace the drain component!
Tony |
