Problem is with a Worcester Bosch 28CDi installed 2 years ago.
System runs without problem for the central heating but (whether the heating is on or off) the boiler makes alarming noises when the hot taps are turned on... it's done this for the last eleven months becoming progressively worse.
When B Gas look they say the system needs flushing (£££!) But how can flushing the radiators (done last year at same time as heat exchanger replaced to fix the same problem) have any effect on the hot water?
They say that it's because the tank for the heating system in the loft is only a few feet above the boiler - which is situated in an upstairs cupboard (location of old hot water tank).
Their solution is to convert the system to a closed one.
Again, this seems to be making changes to address a problem with the central heating when the problem is with the hot water?
I understand that they use the same heat exchanger... but if the system doesn't bang when it's heating the radiators then why does it bang when it's heating the hot water?
Any ideas?
Any ideas?
