DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Best option for wooden flooring
This topic originated from the How to page called Wooden flooring
Click here to return to the page called Wooden flooring.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
Joejr
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 18, 2006 3:43 pm    Post Subject:
Reply with quote Thanks
Hi there ,
I'm building an extension to my lounge which will eventially end up being part solid concrete (the extension bit) and part wooden suspended floor (the existing part of teh room).
Id like to put a solid wooden floor down like oak but as there is a mix of concrete and suspended sub floor I'm unsure what to do.
Should I install a floating floor over teh lot or lift teh old floor boards nailing down the new floor over the beams and gluing over the concrete. Any thougts gratefully appreciated!
Joe
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
m sharp
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 18, 2006 6:44 pm    Post Subject:
if i was you, id lay an engineered floor as a floating floor on underlay. For any information you can get me om matt@shapey.freeserve.co.uk or www.matthewsharp.co.uk.
I dont mind just giving advice if i can help.
Matt
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Wed Apr 19, 2006 8:59 am    Post Subject:
Re: Best option for wooden flooring
Agree with M Sharp about the wood-engineered versus solid floor. Conservatories are prone to have rapid temperature changes and wood-engineered is much more stable to handle that (solids might cup or buckle).
With two different types of underfloors rule of thumb is to make sure you create one type of underfloor (A) for concrete underfloor you need a different type of underlayment than with wood/sheet underfloor; B) different types of underfloor will create different 'climates' under the wooden floor). Simplest thing to do is install hardboard sheets over everything and use foam underlayment for sound-insulation.
__________________
You buy quality, we'll advise. You buy rubbish, we won't!
We're proud members of the BwfA.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Wooden flooring onto concrete 2 640 Wed Apr 12, 2006 11:59 am
Wooden flooring 4 2220 Mon Apr 10, 2006 6:47 pm
Wooden flooring against uneven wall with no skirting 3 260 Tue Apr 29, 2008 4:56 pm
Solid oak flooring on top of wooden floorboards (floating?) 6 540 Sat Nov 24, 2007 6:34 pm
Wooden flooring 2 740 Wed May 25, 2005 7:44 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
