Joined: 19 Apr 2006 Posts: 7 Location: Hertfordshire, United Kingdom Thanked: 0 times
Posted: Wed Apr 19, 2006 6:51 pm Post Subject:
extending hot n cold feed to bath
Hi plumbers. I am replacing my bath suit at the mo. I bought 2 pairs of 15mm braided flexi connecters with ball valves, but forgot the tap thread on the bath is larger.
i cant find a replacement 15mm - 22mm?
am running plasic from the original copper.
no one in homebase/b=q is of any use.
Also have planned to replace the small rad for a heated towel rail. i wish to retain the tails in there upright position.
I have a baxi condensing combi 105 he.
What btu rating towel rad would i need, and where would be the best place for the purchace?
Joined: 04 Aug 2005 Posts: 5488 Location: Yorkshire, United Kingdom Thanked: 19 times
Posted: Wed Apr 19, 2006 7:22 pm Post Subject:
You should be able to get flexis with 3/4 tap connector one end 15mm compression other at a local plumbers merchants.
You can buy special lockshield and TRV which run straight down for towel rails. Naturally they cost more because you need them more so you are prepared to pay a premium.
heat output of towel rail depends on cubic dimentions of bathroom, space available to mount it, and heat retention properties of fabric.
Joined: 19 Feb 2006 Posts: 1653 Location: Nottingham, United Kingdom Thanked: 33 times
Posted: Wed Apr 19, 2006 9:00 pm Post Subject:
reason for different btu' is normally down to the materials each manufacturer uses, same with all rad's. With towel rails also chrome has a lower btu rating than white. This might explain the difference. If you post your room size, ceiling height and number of outside walls someone will give you a rough required btu figure using a mears wheel.
Posted: Wed Apr 19, 2006 9:33 pm Post Subject:
Radiator size roughly allowing for wooden flooring, cavity walls no insulation is 0.65kw 2300 btus. if your new towel rad valve spacings are the same as your pipes at present drain down and replace lockshields with straight through valves designed for towel rads, avaliable from most sheds or merchants.
Posted: Wed Apr 19, 2006 9:41 pm Post Subject:
thanks
sorry to trouble you yet again!
i have a screed floor with the copper running along the eges in a dug out section boarded over the top.
will this affect btu.
is a first floor maiseonnete
as is easily accsesable is it acceptable to couple from copper to plastic to chrome plated copper to towel rad
Posted: Wed Apr 19, 2006 9:51 pm Post Subject:
Wont effect the rating much. I dont advise mixing plastic and chrome plate, some people will say it works in my experience no matter how much i clean off the chrome to reveal copper they seem to blow off after a while. This debate has been had before and now i tend to use compression fittings for chrome.
Just turn off stop cock drain water from lowest point available, (modern instalations have drain off just after stop cock. Put combimate on cold feed to boiler.
If you want to comply with building regs you shopuld fit a trv on the towel rail.
I think that boiler has in built bypass (Is that right gaztpoteng?), but just incase the installer was relying on your bathroom rad you might need to install an automatic bypass (12 quid at merchants) externally between flow and return heating pipes. If you can't solder get two 22mm compression t's a short length of 22mm pipe and some patent compound to help the compression joint seal.
Posted: Thu Apr 20, 2006 9:18 pm Post Subject:
Mix and match all you like. you wont get 15-22 flexi's but will get 15 to 3/4 flexi's either compression or pushfit which is the thread on the bath taps
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
