DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Bosch Diswasher - or not?
This topic originated from the How to page called Plumbing in kitchen appliances
Click here to return to the page called Plumbing in kitchen appliances.
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
  View previous topic :: View next topic
Author Message
Make do and mend
from United Kingdom
Thanked: 0 times
PostPosted: Thu Apr 20, 2006 7:21 pm    Post Subject:
Reply with quote Thanks
Please can somebody help? My dishwasher is not filling with water - it's as if there is a block somewhere. I have checked that the water is on and the pipe is not kinked - any other suggestions? icon_rolleyes.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
andy.budgell
from United Kingdom
Thanked: 0 times
PostPosted: Thu Apr 20, 2006 7:38 pm    Post Subject:
I presume water is coming out of the pipe before it goes into the dishwasher? icon_question.gif
Back to top
 Alert Moderators
lcgs
from United Kingdom
Thanked: 33 times
PostPosted: Thu Apr 20, 2006 8:31 pm    Post Subject:
From my dealings with these dont most Bosch dishwasher come with a large connection (rectangular item) where they connect to the wash tap, normally these contain filters and prv's.
Back to top
 Alert Moderators
Make do and mend
from United Kingdom
Thanked: 0 times
PostPosted: Thu Apr 20, 2006 9:16 pm    Post Subject:
Yes, water is coming through the hose, and the tap is definately on. I wondered whether the actual inlet to the dishwasher may have a shut off valve or something similar, as I did have to disconnect the hose in order to move the dishwasher to decorate. I wondered whether a washer or such may have got lost ?
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Fri Apr 21, 2006 10:35 am    Post Subject:
Is it sensing that the door is shut? When you first start a cycle, the first thing you should hear is the pump running to remove any water left over from the previous wash, then it should open the inlet valve.
Back to top
 Alert Moderators
Make do and mend
from United Kingdom
Thanked: 0 times
PostPosted: Fri Apr 21, 2006 3:03 pm    Post Subject:
Yes, the door is definately closed and the excess water does pump out when the cycle starts. After reading all the repair notes I bought an inlet valve today, replaced the old one but it still isn't working - £25.00 down the drain, so to speak....
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Fri Apr 21, 2006 3:09 pm    Post Subject:
it might be that the water level (air pressure) switch is signalling that the water is already up to level.
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 4 times
PostPosted: Sat Apr 22, 2006 7:38 pm    Post Subject:
Internal blockage on pipework causes this. Not the easiest machines to work on either
Back to top
 Alert Moderators
Make do and mend
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 22, 2006 8:57 pm    Post Subject:
Given up and ordered a new one - not BOSCH as this is the second one in 6 years that has gone wrong. Thank you all very much for your help!
Back to top
 Alert Moderators
macmini
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 22, 2006 10:18 pm    Post Subject:
What make did you go for then?
Bosch is one of the better makes...
Back to top
 Alert Moderators
Make do and mend
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 23, 2006 7:56 am    Post Subject:
John Lewis label for £299 - not sure what make it really is but as it comes with 3 years guarantee as standard and no delivery charges, thought that was a good deal. Had a cooker and hob off of them previousl; both with the three years as standard. The cooker is AEG and no idea what the hob is although it's very similar to the Bosch model. So, fingers crossed!
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Bosch Diswasher problem 4 660 Wed Nov 28, 2007 1:49 pm
Bosch integrated Diswasher - Pump cycle 2 200 Sun Jul 26, 2009 7:59 am
Bosch diswasher slowly filling up of water 3 2560 Fri Jan 21, 2005 2:32 am
Bosch Diswasher SGS3062GB/02 doesn't fill 2 500 Sun Feb 17, 2008 4:41 pm
Diplomat Diswasher ADP8322 not heating up 2 1120 Wed Sep 12, 2007 4:37 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
