Plumbless
Joined: 23 Apr 2006 Posts: 2 Location: Cornwall, United Kingdom Thanked: 0 times
Posted: Sun Apr 23, 2006 10:28 am Post Subject: Drayton Valves Not Operating |
A number of radiators remain very hot even though the Drayton TRVs are screwed down to the defrost setting. The valve's pins do not appear to be stuck and can be depressed ok. Could the valve washers be worn ? If so can they be replaced or do I need new valves ? |
corgiman
Joined: 25 Aug 2003 Posts: 9195 Location: Surrey, United Kingdom Thanked: 2 times
Posted: Sun Apr 23, 2006 9:04 pm Post Subject: |
you need a room stat __________________ If at first you don't succeed, remove all evidence you ever tried. |
Softus
Joined: 21 Oct 2004 Posts: 19532 Location: United Kingdom Thanked: 6 times
Posted: Sun Apr 23, 2006 9:18 pm Post Subject: |
Are the suspect TRV4 bidirectional?
If not, is it fitted on the flow to the radiator?
If so, then it's faulty and needs to be replaced to restore correct operation. |
ChrisR
Joined: 24 Jul 2003 Posts: 18661 Location: London, United Kingdom Thanked: 62 times
Posted: Mon Apr 24, 2006 1:40 am Post Subject: |
Are the trv heads screwed on tight at the fixing collar?? If they're loose your rads will stay hot. |
Plumbless
Posted: Mon Apr 24, 2006 7:00 am Post Subject: |
The valves have an arrow indicating they are one way at the inlet. Heads have been checked as screwed on. It would appear they are not closing properly and therefore looks like I will have to replace them. Thanks very much for all your help. |
ChrisR
Posted: Mon Apr 24, 2006 7:22 am Post Subject: |
IN that case, nowt to lose, try inserting a small disc - a 5p or two may fit - between the head and the pin, so it's definitely pushed down. If the rad then cools you know it's the head which is faulty; if not, it's the valve itself, which I can't remember coming across. |
anotherbodger
Joined: 28 May 2006 Posts: 1 Location: Ipswich, United Kingdom Thanked: 0 times
Posted: Sun May 28, 2006 4:24 pm Post Subject: TRV replacement |
It must be possible to replace just the thermostatic part of the rad valve as on mine they seem to be the problem. Would they have to be the same make as the threads between the valve and head seem very similar between makes.
Of course this will depend on wether it is possible to buy just the head and of course where from.
I expect someone has asked this before but I have not found it |
