DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
manhole cover cracked
This topic originated from the How to page called Rendering
Click here to return to the page called Rendering.
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
  View previous topic :: View next topic
Author Message
mazzzy
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 23, 2006 3:18 pm    Post Subject:
Reply with quote Thanks
I have a manhole cover in my driveway which has cracked. Who would repair this for me?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
2scoops0406
from United Kingdom
Thanked: 1 time
PostPosted: Sun Apr 23, 2006 3:59 pm    Post Subject:
Wouldn't it be cheaper to get a new cover?
Back to top
 Alert Moderators
Scrit
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 23, 2006 5:07 pm    Post Subject:
Re: manhole cover cracked
If it's a pressed steel one it will probably be as cheap to replace it, if it's re-inforced conctrete it will be scrap so replace again as it's probably unrepairable and if it's cast iron you might find a fabrication engineer who'll nickel braze it, although it might still be cheaper to replace it.
Scrit
__________________
Measure twice, cut once - except fingers!
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 22 times
PostPosted: Sun Apr 23, 2006 5:25 pm    Post Subject:
At first read of the original post, i thought mazzzy was referring to ownership of the manhole lid. Just to confirm to him/her, YOU own the manhole and are responsible for the drains on your property icon_wink.gif
Back to top
 Alert Moderators
Hitachimad
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 23, 2006 5:30 pm    Post Subject:
If its cracked i imagine its a Cast iron one...?
Depending on the size its probably easier to buy a new one, start at about £35 i think...Local builders merchant...
Depending on where and how bad its cracked you may be able to get it welded. But could easily cost as much as a new one and not be as good.
Back to top
 Alert Moderators
2scoops0406
from United Kingdom
Thanked: 1 time
PostPosted: Sun Apr 23, 2006 5:32 pm    Post Subject:
Yep, could be construed that way, in which case your answer stands, it's your broken manhole cover, and it is unlikely to be repairable economically or otherwise icon_sad.gif
Back to top
 Alert Moderators
mazzzy
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 23, 2006 6:19 pm    Post Subject:
Thank you for your replys. To make myself a little clearer, the manhole cover is in my driveway near the garage. It is a metal cover and has a crack across it. I cannot replace it myself (not a diyer) and would like to know who would be able to replace it for me.
Back to top
 Alert Moderators
chappers
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 23, 2006 6:28 pm    Post Subject:
you can you measure it go down the builders merchants get a new one lift out the old one and drop the new one in, Even my mother could sort that icon_wink.gif
Back to top
 Alert Moderators
oilman
from United Kingdom
Thanked: 7 times
PostPosted: Mon Apr 24, 2006 8:35 am    Post Subject:
If it's cast iron, the corners of the seal may well be rounded so a pressed steel "replacement" wont fit, unless your mother can tell us different. icon_rolleyes.gif
Back to top
 Alert Moderators
chappers
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 24, 2006 6:35 pm    Post Subject:
my mother would suggest replacing a cast iron one with the same and a pressed steel one (she says that would be unlikely to crack in the first place) with a pressed steel one. icon_smile.gif
Sorry didn't mean to sound sarky in my previous post.
Other alternative is to nick your neighbours during the night.
Back to top
 Alert Moderators
mazzzy
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 25, 2006 8:12 am    Post Subject:
Clappers,
Your last suggestion appeals to me but I wouldnt dare! I have tried the diy stores but can't find a replacement to fit. Thats the trouble, also the surround in which it sits may be rusting and might also need replacing. Would a builder do this job for me?
PS. I am a great grandmother!
Back to top
 Alert Moderators
chappers
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 25, 2006 8:21 pm    Post Subject:
Ahh its actually illeagal for Great grand mothers to touch manhole covers. icon_smile.gif
Yes a builder would be able to sort this for you no problem.
Your one step ahead of my mother she can barely turn a computer on
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Manhole depth? 4 580 Sun Jun 08, 2003 2:06 pm
Cracked Fireplace Insert 3 740 Sun Oct 29, 2006 11:10 am
Cracked china 2 560 Sun Sep 23, 2007 7:24 pm
Repair Cracked Limestone Hearth 2 1740 Wed Feb 06, 2008 12:47 pm
cracked bricks and pointing 3 1920 Sat Oct 12, 2002 10:39 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
