DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
2 way switch from mains
This topic originated from the How to page called Replacing a one way light switch
Click here to return to the page called Replacing a one way light switch.
  View previous topic :: View next topic
Author Message
klee63
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 23, 2006 7:49 pm    Post Subject:
Reply with quote Thanks
I have a 2 way switch from a socket 3 pin plug. wire comes from 3 pin plug to switch and another wire come from light socket. I ganged both brown and blue together and placed them at poler ends of the switch. But fuse box cut out. Any ideas?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Steve
from United Kingdom
Thanked: 22 times
PostPosted: Sun Apr 23, 2006 8:11 pm    Post Subject:
tha wot?
"socket 3 pin plug" <<2 devices there. which is it?
"3 pin plug" <<these contain 13A fuses and have flex connected to them, usually used for powering portable appliances.
"socket" <<wired into the mains, usually in a "ring main" fashion. convenient place for inserting 13A 3 pin plugs.
"light socket" icon_eek.gif icon_eek.gif ¿QUE?
anyway, its obvious what you have done is blatantly wrong despite the bent description. YOU ARE SHORTING LIVE AND NEUTRAL ACROSS THE SWITCH! FFS! how do you expect it to work!!! think about what you are doing!!!!!! What did you think would happen when you connect live and neutral DIRECTLY TOGETHER???
"polar ends of the switch" ¿ehhhh?
If you cant figure it out, PLEASE get an electrician. Think back to school and what a simple switch actually does.
Back to top
 Alert Moderators
cozycats
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 23, 2006 8:18 pm    Post Subject:
Hi crafty How do you get the upsidedown q?marks??
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Sun Apr 23, 2006 8:27 pm    Post Subject:
Re: 2 way switch from mains
I think he means he has a 2 way switch connected to a socket via a plug top.
The flex from the plug top goes to the 2 way switch, then on to the ceiling rose/ batten lampholder.
So he has put both the brown from the mains and the brown from the lampholder to one side of the switch, and the two blues to the other.
So, Crafty is right. You have effectively shorted the two phases together on operating the switch.
You need to link the two neutrals with a connector block. link the two earths in the earth terminal in the switch box, then put the live feed in the common, and the switchwire in L1.
However, I find it odd you have a set-up using flex, plug tops and fixed switches. What are you trying to achieve?
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 22 times
PostPosted: Sun Apr 23, 2006 8:52 pm    Post Subject:
alt+0191
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Mains Halogen Lights - Face Switch Warm 9 1560 Tue Mar 11, 2008 1:11 pm
Standard light switch on mains circuit 8 341 Sun Oct 12, 2008 2:25 pm
Mains, pull switch, lighting adaptor, bathroom, questions! 6 660 Mon Apr 18, 2005 4:00 pm
Mains light switch to dimmer 14 2940 Sat May 05, 2007 3:28 pm
Dimmer Switch on mains fluorescent downlighters? 6 160 Tue Jun 09, 2009 10:47 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
