underfloor heating
24 Apr 2006
Wiltshire
i have wired my under floor heating and im not sure what the volt free outputs are for on the valve i have a blue that is nutral, the brown shows to be with the pump and out going of the high limit stat but not sure about orange or gray/ at the mo i have per live to gray and or is to pump and boiler. any help?
The volt free contacts control your pump/boiler depending on your wiring configuration.
The boiler/pump feed is wired through the contacts to stop them running when the valve is closed. You may have other valves in the house which control your heating and hot water. If this is the case and you want to control your under floor heating as a separate timed zone you need to wire them in parallel with the contacts on the other valves.
How do you want to control the under floor heating?
