DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
ceiling rose in bedroom
This topic originated from the How to page called Identifying a faulty circuit
Click here to return to the page called Identifying a faulty circuit.
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Electrics UK
  View previous topic :: View next topic
Author Message
andrewh
from United Kingdom
Thanked: 0 times
PostPosted: Fri Apr 28, 2006 4:45 pm    Post Subject:
Reply with quote Thanks
hi hope somebody can help i took down the ceiling rose to decorate noted on paper where each lead went ie switched neutral to live, reds to centre three connectors, neutral to neutral but now light won\\\'t work please please help me ! icon_redface.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Rusty2
from United Kingdom
Thanked: 0 times
PostPosted: Fri Apr 28, 2006 5:02 pm    Post Subject:
Hi - i recently found some good advice on someone elses question - they were asking about how to identify a set of rose wires. Try looking that one up.
Good luck!
Back to top
 Alert Moderators
Pens
from United Kingdom
Thanked: 0 times
PostPosted: Fri Apr 28, 2006 5:51 pm    Post Subject:
For reference, you can identify the switch cable when you have 3 cables at a light without a meter by carrying out the following:
1. Turn the power off
2. Connect all earths together.
3. With the light switch in the off position connected any two cables together red to red - black to black or if you have the new colours blue to blue - brown to brown.
4. Turn the power back on and check around the house to see if all other lights work. If they do then the spare cable is the switch cable. If they don't then turn the power off and repeat the above using the spare cable and one of the others.
5. Repeat the above until you have all the lights in the house working and one spare cable which will be the cable to the switch.
To make identification easy at second fix some sparks used grey 1.0mm for the switch wire and white 1.5mm for the feeds so that would be a good starting point when
Back to top
 Alert Moderators
Pens
from United Kingdom
Thanked: 0 times
PostPosted: Fri Apr 28, 2006 5:55 pm    Post Subject:
When you sorted out which cable is which wire as follows
http://www.diynot.com/forums/viewtopic.php?t=7553&postdays=0&postorder=asc&start=45
Back to top
 Alert Moderators
ridders74
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 29, 2006 5:33 pm    Post Subject:
I've done the same. Blown the lighting circuit fuse, replaced the fuse but now no lights work in the house.
BTW I have fixed the problem that cause the fuse to blow.
HELP!!!!
see forum rules 17 & 20
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Electrics UK All times are GMT
Page 1 of 1
Jump to:
Fitting a ceiling light to a bedroom 7 380 Thu Aug 31, 2006 9:59 am
ceiling fan in bedroom, help needed please. 3 100 Sun Feb 15, 2009 1:48 pm
Bedroom ceiling light not working 2 120 Wed Mar 18, 2009 10:41 am
Recessed spotlights in bedroom 16 800 Sun Mar 11, 2007 9:44 am
bedroom light 12 480 Fri Dec 22, 2006 10:13 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
