shadrack
Joined: 18 Nov 2004 Posts: 7 Location: United Kingdom Thanked: 0 times
Posted: Wed May 03, 2006 11:25 am Post Subject: Why open stand pipe? |
I am re-positioning a washing machine and have sawn off and extended the existing 32mm washing machine drain pipe by 1.5m, routing it round a couple of corners and finishing with a 45 degree open pipe at a height of about 700mm or so. Unfortunately I now find that when the machine empties there is always a splash of water back out of the pipe - I guess it is because I have increased the resistance to the flow of water, and so the pipe backs up temporarily.
I assumed that an easy fix would be to fit a spigot-type hose adaptor at the end of the pipe (and finding the right combination of fittings is proving harder than I expected!), but most people seem to advocate the open pipe scheme. Why? With an open pipe if a blockage develops the machine will flood the room, whereas with a watertight hose adaptor nothing will happen. Or is there more to it than that? |
Diyisfun
Joined: 15 Jun 2004 Posts: 4113 Location: London, United Kingdom Thanked: 9 times
Posted: Wed May 03, 2006 11:36 am Post Subject: |
I think if there is a blockage the machine will know there is & stop pumping. My machine is connected very much as you have described & I have not had any problems. |
bathjobby
Joined: 06 Oct 2004 Posts: 1052 Location: United Kingdom Thanked: 0 times
Gees
Joined: 19 Apr 2003 Posts: 550 Location: Durham, United Kingdom Thanked: 2 times
Posted: Sat May 06, 2006 7:59 pm Post Subject: |
An "air Break" is by far the best method of draining a washer / dishwasher to the outside world. It prevents any back syphoning of dirty water into the appliance. A vertical section of pipe 8 - 10 inches long is all you will need to prevent any splashback.
As for the pump stopping if there is a blockage.... don't you believe it.!! |
