DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Partly Blocked Drain
This topic originated from the How to page called Clearing blocked drains
Click here to return to the page called Clearing blocked drains.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
tomlith
from United Kingdom
Thanked: 0 times
PostPosted: Thu May 04, 2006 8:49 pm    Post Subject:
Reply with quote Thanks
I have an old property and I am rennovating one of its outbuildings. The drainage from this part of the outbuildings is 4 in diameter fireclay pipe, but until I set about it it did not have any access for rodding and so cannot have been cleared since it was laid ( I think shortly after the War). There is a 30 m length which I can get my rods down with a traveller wheel on the end or with one of those corkscrew like devices. But the rods stop dead if I put anything larger down. Water flows down the pipe, but without the rush which I would expect, as the pipe is at a reasonable grade.
Does anyone have any ideas about how I can get this properly cleared?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Thu May 04, 2006 9:06 pm    Post Subject:
only a thought.
shove your rods down with plunger thingy (tehnical term that is) measure how far down it goes, then dig pipe up at that point
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
lcgs
from United Kingdom
Thanked: 33 times
PostPosted: Thu May 04, 2006 9:18 pm    Post Subject:
Does this length of pipe take soiled water or rain water. If rain water could just be an old soakaway which is why rod stops dead. If it runs to a main drain for soil water you could be digging.
Lee
Back to top
 Alert Moderators
doitall
from United Kingdom
Thanked: 240 times
PostPosted: Thu May 04, 2006 9:40 pm    Post Subject:
Could be a cesspit and not on the main drain
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 32 times
PostPosted: Fri May 05, 2006 9:32 am    Post Subject:
one of the joints has dropped on the 4inch saltglazed pipes that are 2 foot long .......more chance of it being done properly when yours was ...than you will find on any new estate today icon_rolleyes.gif My psychic eye never lies icon_lol.gif
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 193 times
PostPosted: Fri May 05, 2006 11:21 am    Post Subject:
There also the possibility that there is a trap ( or u bend ) or a rapid change of direction.
If there really is a soft blockage which sounds unlikely ther pressure jetting would go around most bends but I dont think that is the case.
At the distance where it "just stops" whats on the surface ??? Could there be an inspection chamber which has got covered over.
It could also be a "T" connection onto a larger sewer.
Many possibilities and digging at exactly the stop point might be the low tech solution.
I am surprised that DIA did not mention the high tech CCTV option. The small cameras are so small and cheap now that you could put one in a bottle and seal the top and tape it onto your rods and watch as you go !!!
Tony
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Partly cold house - help please gurus 11 500 Sun Nov 23, 2008 1:40 pm
combined feed and vent pipe partly in plastic??? 13 1460 Thu May 04, 2006 6:22 pm
blocked wast drain 2 4280 Thu Nov 16, 2006 9:56 am
blocked drain? 6 420 Sat Jan 05, 2008 12:21 am
Blocked Drain 4 460 Thu Oct 18, 2007 10:54 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
