zanussi aquacycle 1200 fle 1216w
6 May 2006
Leicester
hi, can anybody help, my machine will start, but suddenley it stops working, the pause-start button starts flashing and it just keeps bleeping.. any ideas?
downloaded the manual, its saying that the door is not shut.. however it is!!! red light is on and everything... hope its not a pcb problem
as you have it and i dont, what do the instructions say, and if you have lost them try going on line for new ones
[downloaded manual.. thanks/ howver the fault code is saying door is open.. its shut and even the red light is on!!! any ideas?
since the m/c thinks the door is open, its either the door catch, the door interlock or a loose / broken wire
ok, will look along those lines, only had the machine three years.. dont they make things to last any more... anyway thanks fot the help!!
they dont make stuff to last anymore as it happens, its all down to
...............well our m/c is £5 cheaper than yours, so some one makes it cheaper than that, and so it goes on, the way they do it is to use lots of cheap components.
Origonaly counter weights on w/m's were steel, now they are concrete
