DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
New bath..new leaks
This topic originated from the How to page called Installing a bath
Click here to return to the page called Installing a bath.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Zed786
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 07, 2006 10:13 am    Post Subject:
New bath..new leaks
Reply with quote Thanks
Just installed a new cheapy bath (from B&Q). It's a very tight fit and i\\\'ve screwed the feet in. However, lookin back perhaps i should have done that after connecting the pipework. I've connected the cold tap to the cold supply but i had to force the old copper pipe to the new tap. There is a leak just on the not. It\\\'s more of a weeping leaking than a full blown leak. Also, the strangest leak it the one on the drainage pipe on the elbow joint from the trap.
Would be grateful if anyone could get me out of this mess.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Bahco
from United Kingdom
Thanked: 5 times
PostPosted: Sun May 07, 2006 1:30 pm    Post Subject:
Your tap is not lining up with the pipework, easiest fix is to fit a flexi hose to it.
As for your waste, check alignment and change elbows , waste if you need to. icon_biggrin.gif
__________________
85 weeks without smoking!
Back to top
 Alert Moderators
Expertboy
from United Kingdom
Thanked: 1 time
PostPosted: Sun May 07, 2006 9:06 pm    Post Subject:
Re: New bath..new leaks
Zed786 wrote:
I always get the appliance in place and then pipe up to it. As suggested get yourself a flexihose for the copper pipe, and check that the rubber seals are in place properly on the plastic waste connections, sometimes sliding the nut onto the pipe followed by the rubber washer and the screwing it together helps.
__________________
i accept no responsibility for any of your mistakes whether you took my advice or not icon_smile.gif
Back to top
 Alert Moderators
Zed786
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 07, 2006 9:17 pm    Post Subject:
New Bath....New leaks
Thanks for your advice lads.
I've managed to sort the taps out. I used speedfit connections for the cold water supply. Managed to get it working after a bit of a struggle. The place i bought the conenctions from said that speedfit straight couples are made so that copper pipes simply insert into them without an olive or anything!! BUT he didn't say you've got push them right in. For the hot water supply i used the exisiting copper pipe/nut and used plenty of PFTE tape.
HOWEVER, THE DRAIN FROM THE TRAP IS STILL LEAKING. It is NOT the waste from the bath. It is the grey elbow from the grey pipe i.e the piping that takes the water to outside. Tried getting a elbow but the guy didn't have any 2inch in stock but i am really worried about this last piece. I tried PTFE tape and silicon but no joy.
No water.....2 days and counting
Thanks for any comments/advice
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Mon May 08, 2006 12:28 am    Post Subject:
Are you sure it's 2"? They're normally 1½"
There are compression, pushfit and solvent weld(glue) types. Suggest you try a compression one cos it'll fit any type of (say) 1½" .
If you're new to them it's easy to assemble them wrongly though - you HAVE to put the nut, backing washer(if it has one) then the rubber washer on the pipe first, thin edge of the rubber washer towards the fitting.
Back to top
 Alert Moderators
Zed786
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 08, 2006 8:24 pm    Post Subject:
Hi thanks for that Chris,
It's definitely 2inch as that is what the guy at the plumber's merchant said. Managed to get one from another supplier. Fitted it and working perfectly (thank God). I could swear that the old elbow had brand new seals but the guy at the store said to feel around the inside of the old and compare with the new one and there was definitely a difference My point being looking isn't always believing. The midas touch did it for me this time.
Once againg thanks for all your advice/suggestions lads.
Keep up the good work!
Zed
PS: Just got the toilet, basin and shower to put in now!!
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Heat leaks 14 1780 Sun Apr 16, 2006 7:27 am
wall hung wc leaks 18 900 Mon Jul 03, 2006 7:50 pm
Isolation Valve Leaks 2 520 Mon Jan 02, 2006 2:36 am
Pressure dropping / leaks 5 2340 Sat Dec 31, 2005 8:01 pm
Glow worm swiftflow 80, drain point leaks 2 560 Sat Nov 05, 2005 1:28 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
