DIYnot
Local | Network
   DIYnot > Forums
Local | Network
recurring Weeds between patio slabs
Post new topic   Reply to topic    DIYnot.com Forum Index > In the Garden
Author Message
larrydiy
from United Kingdom
PostPosted: Sun May 07, 2006 10:30 am Reply with quote
Hi
Can anyone suggest how to go about to deal with persistent weeds growing between slabs on a permanent basis?
larry
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Sun May 07, 2006 11:38 am Reply with quote
the weeds grow because of a few things:
there is not enough "traffic" to kill them as they grow up
there is something for them to grow in
they want to P*** you off
Although a lot of effort for little gain, you could lift all the slabs, lay a weed proof membrain.
Remove the existing grouting and re point it with sand and cement (and a sprinkle of weed killer)
Spray area with weed killer every spring and again a bit later on in the year.
Its the fact that you dont walk enough on it that is the real problem (honest) we have a tarmac path, the bits that get rgularly walked on by us and neighbours etc is clear of any weeds, but the little side bits do get weeds, (Liitle traffic) its also the same reason you dont see weeds on a road (if ever you see in films old dissused runways you will see weeds because there is no traffic to kill them)
Back to top
 Alert Moderators
Thermo
from United Kingdom
Thanked: 148 times
PostPosted: Sun May 07, 2006 3:58 pm Reply with quote
most of the path clears will do the job, but the best is as breezer says, repoint it
Back to top
 Alert Moderators
sandwell
from United Kingdom
PostPosted: Fri May 12, 2006 11:04 pm Reply with quote
Pathclear is good, because it lasts the whole season, not impressed with it in the spray bottles though, I prefer to mix it in watering can, and pour in the cracks that way.
Rather than lifting the slabs, and laying some weed proof membrane, try sqeezing some strips of membrane down the gaps with an old knife. I have done this, and it works fine.
Back to top
 Alert Moderators
Thermo
from United Kingdom
Thanked: 148 times
PostPosted: Sat May 13, 2006 6:38 am Reply with quote
theres no point in putting a weed proof memebrane down under all the slabs. proper pointing will stop them coming through
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1511 times
PostPosted: Sat May 13, 2006 10:18 am Reply with quote
I'm another Pathclear supporter, but, once you've put it on, don't disturb the soil surface e.g. by hoeing or pulling up weeds. It works by putting a thin non-germinating layer on the surface of the soil, so if you disturb it, more weeds will grow. If that happens, apply a bit more (from your red watering can)
Back to top
 Alert Moderators
jackpot
from United Kingdom
Thanked: 4 times
PostPosted: Mon May 29, 2006 8:00 pm Reply with quote
see forum rule 20
Back to top
 Alert Moderators
sokar
from United Kingdom
PostPosted: Mon Jun 05, 2006 10:28 am Reply with quote
White vinegar
Back to top
 Alert Moderators
markvirgo
from United Kingdom
Thanked: 1 time
PostPosted: Mon Jun 19, 2006 11:05 pm Reply with quote
re point with geofix its not cheap but does the job
Back to top
 Alert Moderators
Pushfit
from United Kingdom
PostPosted: Thu Jul 27, 2006 8:43 pm Reply with quote
Use a salt cellar and sprinkle salt along the joins every month or so. It only takes a short time but does a good job in keeping ordinary weeds down.
Back to top
 Alert Moderators
loublou
from United Kingdom
PostPosted: Fri Jul 28, 2006 11:08 pm Reply with quote
burn them with a gas weed lance or just a blow torch if you have one.
If you do it really well a couple of time burning out the roots you will knock them on the head.
Repeat as and when but I find if you go round and burn all the cracks late summer you burn any seeds that have blown in.
Back to top
 Alert Moderators
spice
from United Kingdom
PostPosted: Sat Jul 29, 2006 10:55 am Reply with quote
I have membrane under my slabs, and the little blighters still come thru, it doesnt help that OH has loads of bird feeders all over the place, and the birds are dropping seeds.
I pull them out bit at a time, as patio is quite big, then whack a solution of weed killer, but it still wont stop the problem of seeds blowing in and rooting though.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1511 times
PostPosted: Sat Jul 29, 2006 11:18 am Reply with quote
I still say "Pathclear" once or twice a year.
Back to top
 Alert Moderators
Thermo
from United Kingdom
Thanked: 148 times
PostPosted: Sat Jul 29, 2006 3:45 pm Reply with quote
they dont come through from under the slabs. they grow in the cracks of the pointing, a membrane underneath matters not one......hang on i said all this a few months ago!
Back to top
 Alert Moderators
Ghandalf
from United Kingdom
PostPosted: Sun Jul 30, 2006 11:18 pm Reply with quote
larrydiy wrote:
Hi
larry
Hi larrydiy
Hope you don't mind me jumping in here.......If you do decide to use a weedkiller,make sure it's systemic. This will be taken by the weed right through it's entire system down to it's roots. No chance of it coming back ....unless new seed germination. Some weeds (Japanese Knot weed) have roots/rhizomes 30ft long...tenacious little blighters.
Ghandalf
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > In the Garden All times are GMT
Page 1 of 1
Jump to:
Weeds growing and repointing paving slabs 2 2580 Tue Jun 06, 2006 8:25 pm
Patio weeds on possible property purchase...anything nasty?? 8 320 Tue Jul 03, 2012 4:41 pm
how to kill weeds before new turf is laid 4 180 Thu May 17, 2012 4:03 pm
Cutting tall grass/weeds 7 200 Mon Jul 16, 2012 7:57 pm
Nuke the weeds! 23 640 Sat Jun 22, 2013 9:49 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
