| Author |
Message |
fatboy1a
Joined: 07 May 2006 Posts: 4 Location: Hertfordshire, United Kingdom
Posted: Sun May 07, 2006 1:29 pm |
Does anybody know where I can download user instructions for the vaillant VCW-Sine 18T3WFH combi boiler 65kBTU? Ive tried the vaillant site without success and cant find it anywhere else.
Thanks |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
Gasguru
Joined: 09 Sep 2005 Posts: 5442 Location: London, United Kingdom Thanked: 554 times
Posted: Sun May 07, 2006 2:07 pm |
What do you need to know? |
| Back to top |
fatboy1a
Posted: Sun May 07, 2006 2:52 pm |
Basically my boiler is leaking, not sure which part is leaking though. I have called someone out for it and they asked if I had the user manual. They said that this would allow them to order the correct parts for the boiler if any need replacing. Just need to find a downloadable manual. |
| Back to top |
Gasguru
Posted: Sun May 07, 2006 3:34 pm |
I'd be wary of someone turning up to fix a boiler with no manuals - any reputable and competent engineer will have their own set of manuals and not rely on the customer.
Part numbers are easily identified at the merchants.
I look after several T3's installed as far back as the early 80's although complicated boilers they have several years life left in them. |
| Back to top |
raden
Joined: 05 Apr 2006 Posts: 1020 Location: Indonesia Thanked: 5 times
Posted: Sun May 07, 2006 4:19 pm |
I'm not sure that anybody who knew what they were doing would need a manual to identify a leaking part. I would also have thought that the most likely place for a leak would either be from the heat exchanger or a joint
I think I have a manual at work if you really do need one |
| Back to top |
ChrisR
Joined: 24 Jul 2003 Posts: 23083 Location: London, United Kingdom Thanked: 936 times
Posted: Sun May 07, 2006 7:02 pm |
Can email it to you but be warned it's nearly 12Mb. Many isp's don't allow files that big... |
| Back to top |
doitall
Joined: 08 Jan 2005 Posts: 16510 Location: Bath, United Kingdom Thanked: 1103 times
Posted: Sun May 07, 2006 7:05 pm |
| ChrisR wrote: | | Can email it to you but be warned it's nearly 12Mb. Many isp's don't allow files that big... |
is it in pdf Chris.
I would love a copy please
john |
| Back to top |
Soggy_weetabix
Joined: 20 Dec 2005 Posts: 1639 Location: Bedfordshire, United Kingdom
Posted: Sun May 07, 2006 8:54 pm |
Me too Chris.
Sick of 'making' rubber washers to stop em leaking.
PRV's in patrticular.
David |
| Back to top |
raden
Posted: Sun May 07, 2006 9:03 pm |
moi aussi |
| Back to top |
ChrisR
Posted: Mon May 08, 2006 12:33 am |
Yes pdf - it's a big manual. Tried zipping it for kev - it doesn't shrink. Now have Acrobat Pro so could try converting it to lower res or splitting it if required, but I'll try sending it as is, but expect it to bounce back....
fatboy post your email to me or put it in your profile or type fatboyATispDOTcom or something |
| Back to top |
fatboy1a
Posted: Mon May 08, 2006 7:50 am |
Chris my email is dave210 @dave210 .plus.com
Cheers |
| Back to top |
fatboy1a
Posted: Mon May 08, 2006 7:56 am |
Raden and Gasguru,
Good point about the manuals, suddenly I think I will find someone else! Dont want to try myself as I have a talent for turning a relatively simple job into a major disaster area!! |
| Back to top |
Agile
Joined: 26 Jun 2004 Posts: 46043 Location: London, United Kingdom Thanked: 2525 times
Posted: Mon May 08, 2006 10:03 am |
Statistically the most common leakage is from the AAV which is just behind and to the right of the pump.
Boiler then drips from the real right.
I would be very suspicious of an engineer who required you to have a service manual for such a common boiler! Not all engineers are familiar with this model but a mere leak is a low tech fault!
Tony |
| Back to top |
