DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Extractor fan noise
This topic originated from the How to page called Installing wiring for an extractor fan
Click here to return to the page called Installing wiring for an extractor fan.
  View previous topic :: View next topic
Author Message
getonwithit
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 07, 2006 3:29 pm    Post Subject:
Extractor fan noise
Reply with quote Thanks
Can anyone help me solve the problem with extractor noise causing distress to my next door neighbour. The problem is my in-line fan being secured to the roof truss (screwed) with the hum noise being picked up next door at night. I have turned down the over run but I really need to secure the fan to something else that will not transfer the noise. Any ideas would be greatly appreciated.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
SparkyMarky
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 07, 2006 5:08 pm    Post Subject:
Is the fan screwed directly to the roof truss? If so you could try fitting some rubber bushes between the feet of the fan and the truss to prevent the vibration being transferred from the fan to the timber. This is probably what is creating the hum. Have a google for "anti vibration mounts" to see the type of thing I mean (although a lot of the results will probably be for industrial machinery)...
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 73 times
PostPosted: Sun May 07, 2006 5:41 pm    Post Subject:
or try putting the screws through a few ¾" tap washers
Back to top
 Alert Moderators
SparkyMarky
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 07, 2006 5:52 pm    Post Subject:
If you try this then sandwich some washers between the head of the screw and the fan feet as well. To prevent the vibration being transferred you need to make sure there is no direct contact between the fan and either the truss or the screws. Go for the softest rubber washers you can find as well (but not so soft that the fan squahes them flat!)
Back to top
 Alert Moderators
bathjobby
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 09, 2006 8:47 am    Post Subject:
You invariably never get rid of all the vibes doing these sort of things. Do the decent thing by your neighbour and spend a few £s and replace your inline with a ceiling mounted fan as far from the adjoining wall as possible. Not worth making an enemy for a few £s.
Back to top
 Alert Moderators
The Wholesaler
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 09, 2006 9:04 am    Post Subject:
anyone fitted the airflow icon fans? i've sold loads and even sold myself one, but when it half opens it sounds like a jumbo jet is about to take off!
Back to top
 Alert Moderators
bathjobby
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 09, 2006 9:15 am    Post Subject:
Yes, couple on months ago. I have the same observations but as you say, its only whilst the iris is opening and I can live with that for the better extraction rate (113 cm per hour down 100mm ducting vs the standard 73-83 or thereabouts).
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
buzzing noise 7 420 Thu Feb 01, 2007 2:57 pm
Clicking noise 10 440 Thu Feb 01, 2007 8:30 pm
Bathroom fans and perceived noise 5 540 Thu Jul 12, 2007 3:35 pm
Buzzing noise from MCB 8 540 Thu Jan 11, 2007 12:33 pm
buzzing noise from electric control panel 14 860 Thu Jan 11, 2007 12:44 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
