DIYnot
Local | Network
   DIYnot > Forums
Local | Network
combi boiler wiring diagram
Author Message
sime27
from United Kingdom
PostPosted: Sun May 07, 2006 4:49 pm Reply with quote
Can 1 of you lot draw me a detailed wiring diagram for a modern combi boiler? (please include types of cable)
This must include switched fused spur off ring , external digital siemens time clock , external thermostat and 3 pole switch for isolation next to the boiler (live , neutral and switched live)
Back to top
 Alert Moderators
simon_d
from United Kingdom
PostPosted: Sun May 07, 2006 9:25 pm Reply with quote
more importantly, why do you have to ask this. if your installing a boiler and not 100% of the wiring to the boiler, check the installation manual. (and if you can understand that, call someone who can)
otherwise ask your lecturer. dont expect others to do your work for you. what happens when your on your own?
asking the odd question that your stuck with, like your stuck with how the stat works etc is fine, but asking us to do YOUR work is not.
Back to top
 Alert Moderators
sime27
from United Kingdom
PostPosted: Mon May 08, 2006 2:36 pm Reply with quote
I only ever wired ones with internal controls with the fused spur outlet as the isolator.
never done 1 with external stats and 3 pole isolator so any help will be much appreciated
Back to top
 Alert Moderators
sime27
from United Kingdom
PostPosted: Tue May 09, 2006 5:30 pm Reply with quote
does this sound right?
3amp Spur off ring with 2.5 twin and earth
live neutral and earth out of that into the time clock to feed that
then live and neutral out from the same terminal for the permanent live to the boiler
the from the load side of the switched terminal of the time clock run 2 brown core and earth to the thermostat.
then from the outgoing side of the thermostat conect this to the switch switch wire of the boiler?
which then gives me live neutral and switched live at the boiler which i connect up into the 3 pole isolator..
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 211 times
PostPosted: Tue May 09, 2006 5:36 pm Reply with quote
I thought modern combi boilers have all this kit built in and all you have to do is run a bit of flex from the boiler to the FCU. (and an optional room stat) icon_eek.gif
Back to top
 Alert Moderators
sime27
from United Kingdom
PostPosted: Tue May 09, 2006 5:39 pm Reply with quote
not built in on this 1 mate as they having it fitting in a loft so external controls are needed
Back to top
 Alert Moderators
RMS
from United Kingdom
Thanked: 77 times
PostPosted: Tue May 09, 2006 5:52 pm Reply with quote
Does your boiler not have a wiring diagram in the installation manual showing the connection fo external controls, if not there should be a diagram showing the wiring of all the components internal to the boiler and you can then connect your prog. to suit.
Back to top
 Alert Moderators
sime27
from United Kingdom
PostPosted: Tue May 09, 2006 6:02 pm Reply with quote
yeah i know the wiring at the boiler end after the 3 pole isolator i have 2 flexs 1 is the supply live neutral and earth. the other is 2 core witch is switched live and neutral.
I just want to know if my side of the 3 pole isolator sounds right?
Back to top
 Alert Moderators
simon_d
from United Kingdom
PostPosted: Tue May 09, 2006 9:38 pm Reply with quote
thats right. altho if you cant get a 3pole switch, use 2pole (make sure it doesnt have a neon) and dont switch the neutral (its already DP switched earlier down the line)
and you best use 3core and earth to stat - some require neutral/
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Wiring Diagram for a BAXI WM 511 RS boiler needed 2 1060 Thu Apr 27, 2006 1:41 pm
wiring up combi boiler 11 980 Sat Sep 19, 2009 4:11 pm
Valliant combi boiler (wiring) 5 1101 Wed Aug 06, 2008 9:41 pm
Wiring combi boiler to spur 8 661 Mon Nov 23, 2009 7:20 pm
Wiring wireless room stat into Combi boiler 13 1320 Tue Dec 14, 2010 9:21 am
DIYnot
