christaylor
Joined: 08 May 2006 Posts: 3 Location: United Kingdom Thanked: 0 times
Posted: Mon May 08, 2006 2:11 pm Post Subject: Sink, dishwahser and washing machine plumbing off one source |
Hi there,
I'm installing my kitchen and would like to run the washing machine, dishwasher and sink all of a single pair of hot and cold water pipes (both the dishwasher and w/machine only need cold water). I will also need to use a single waste.
Is this possible?
Would it just be a case of running 2 consecutive Y joints off the cold pipe?
The waste stand pipe is also 1m from the sink (down by the w/machine)...will this be a problem?
Cheers, Chris  |
Diyisfun
Joined: 15 Jun 2004 Posts: 4113 Location: London, United Kingdom Thanked: 9 times
Posted: Mon May 08, 2006 2:18 pm Post Subject: |
You shouldnt have any problems feeding the machines, as the machines will take water by volume not time & the chances are its mains pressure anyway.
Re the waste if you intend to discharge the waste ito the one downpipe this could give a problem. Would it be possible to discharge one waste into the sink trap? |
christaylor
Posted: Tue May 09, 2006 12:30 pm Post Subject: |
Hi, thanks. I actually only have a single waste exit pipe for all three (sink, d/wahser and w/machine).
Whatv sort of fitting would be best to split the incoming water supply into 3? |
Diyisfun
Posted: Tue May 09, 2006 1:26 pm Post Subject: |
I would use a T for each then put a valve on that. This will let you isolate individually. |
christaylor
Posted: Tue May 09, 2006 6:27 pm Post Subject: |
cheers mate. I'll give it whirl |
