DIYnot
Local | Network
   DIYnot > Forums
Local | Network
socket spanner size for bath tap monoblock
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
sknight
from United Kingdom
PostPosted: Mon May 08, 2006 8:36 pm Reply with quote
My bath tap is dripping and I need to check out the washers/orings on the monoblock.
The monoblock valve is set into the tap any the only way to remove it is with a socket, I'm not sure of the size.
tried a 16mm too small, 17mm seems a little too big any ideas.
This is the tap.
http://www.mfi.co.uk/mfi/FinalProduct.asp?CT=/4020/YourBathroom&CT=/YourBathroom/BathroomTaps&CT=/YourBathroom/BathroomTaps/BathTaps&CT=*&SKU=BTP1054
Thanks for any help
Back to top
 Alert Moderators
relief123
from United Kingdom
PostPosted: Mon May 08, 2006 9:12 pm Reply with quote
have you tried any imperial sockets
Back to top
 Alert Moderators
chrishutt
from St. Pierre and Miquelon
Thanked: 20 times
PostPosted: Mon May 08, 2006 9:17 pm Reply with quote
It's normal to undo the tap mechanism with an adjustable spanner rather than a socket.
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1094 times
PostPosted: Mon May 08, 2006 9:25 pm Reply with quote
That
isn't a monobloc.
Which nut do you mean?
IS there a chrome collar in the way or something? If so it might unscrew more easily if you've warmed it up (boiling water)
5/8" is smaller than 16mm, 11/16" is bigger than 17, so imperial wouldn't help.
Back to top
 Alert Moderators
relief123
from United Kingdom
chris i was thinking the same..
Back to top
 Alert Moderators
LeeC
from United Kingdom
Thanked: 3863 times
PostPosted: Mon May 08, 2006 9:37 pm Reply with quote
Just below the tap handles sits a chrome collar. this will unscrew and lift up to reveal the body of the tap which can then be undone using a 16.5mm adjustable spanner icon_lol.gif
lee
Back to top
 Alert Moderators
sknight
from United Kingdom
PostPosted: Tue May 09, 2006 7:01 pm Reply with quote
OK, the top handle unscrews with a long 2 inch screw.
You can then pull out what looks like a spacer 1.5
The tap handle sits on a splinned part of the spacer and the spacer sits on a splinned bit of the valve.
You then remove the top chrome part of the tap by unscrewing the grub screw at the back. This removes about 1.5 of the chrome part.
The Valve looks like its sits in the centre part of the tap recessed by about 0.5.
(Ie from the picture the tap looks like each side is in 3 pieces., the valve is in the middle part recessed by about 0.5)
I have tried 17mm and 11/16 just too big
16mm and 5/8 just too small.
16.5mm sound like the right size lcgs
Any ideas
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1429 times
PostPosted: Tue May 09, 2006 7:04 pm Reply with quote
lcgs wrote:
lee
sorry, I've been out and measured, the nearest size I've got in an adjustable spanner is 16.772mm
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1094 times
PostPosted: Tue May 09, 2006 10:52 pm Reply with quote
You're undoing it so you need a left handed adjustable spanner...
Seriously though it sounds mad if you really need a socket.
You could try cutting up a tin can and bending a small strip with pliers, to go between the socket and the hex .
You could try a box (tubular usually Melco) spanner and squash it a bit first in a vice (or hammer!)
I have also used long-nosed pliers with mole grips across them for such things icon_redface.gif
Otherwise a 21/32nds ring spanner...
Having found the monobloc one - are you saying the marked sleeve doesn't come off???
(click it it grows)
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1429 times
PostPosted: Tue May 09, 2006 10:56 pm Reply with quote
After you've pulled off as much of the shroud as you can, if you put the knob back on the splines and turn it, will it wind the nut out enough to grab it?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Long immersion spanner 2 180 Thu Oct 07, 2010 7:18 pm
Wide jaw adjustable spanner. 11 400 Thu Feb 24, 2011 3:29 pm
Recommend a tap spanner 7 740 Mon Dec 07, 2009 6:08 pm
Megaflo Immersion Spanner 7 540 Tue Jun 09, 2009 8:36 pm
spanner for removing basin waste back nut ??? 8 1600 Mon Mar 24, 2008 8:37 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
