DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
FENCE POST ANCHORING
This topic originated from the How to page called Different ways of anchoring the fence posts
Click here to return to the page called Different ways of anchoring the fence posts.
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
  View previous topic :: View next topic
Author Message
KGARDEN
from United Kingdom
Thanked: 0 times
PostPosted: Fri May 12, 2006 8:21 pm    Post Subject:
Reply with quote Thanks
Can I use bolt-down fixings to attach wooden fence posts to non-mortared concrete patio slabs?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Fri May 12, 2006 9:33 pm    Post Subject:
Erm, yes, but not if you want the fence to stay up!
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Fri May 12, 2006 9:51 pm    Post Subject:
KGARDEN, need more info, for a low height fence should be okay
__________________
Always judge a man by the way he treats someone who is of no use to him
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Fri May 12, 2006 11:38 pm    Post Subject:
I think it will go over when the wind blows. Is there a reason why you don't want to dig holes in the ground?
Back to top
 Alert Moderators
KGARDEN
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 13, 2006 8:08 pm    Post Subject:
Hi, thanks everyone for replying to my question about using bolt-down fixings and patio slabs. The fence is a picket fence about 90cm high, and there will be a gate too. The reason I was hoping to attach the posts to the patio and not dig holes was because the patio isn't very big (200cm x 200cm) and I'm reluctant to lose any patio area by removing the slabs to dig the holes if it isn't necessary. I thought about cutting the slabs so as to lose as little space as possible, but I've been told I'd need a grinder.
My 'plan B' is - The patio is elevated, and there is a conrete frame around the patio which is about 10 cm high, can anyone advise me as to whether it would be possible to drive a bolt through the posts and into the concrete from the side instead? (The concrete is about 10 cm thick.)
Any further help much appreciated. Thanks -
Back to top
 Alert Moderators
Scrit
from United Kingdom
Thanked: 0 times
PostPosted: Sat May 13, 2006 9:19 pm    Post Subject:
Re: FENCE POST ANCHORING
KGARDEN wrote:
My 'plan B' is - The patio is elevated, and there is a concrete frame around the patio which is about 10 cm high, can anyone advise me as to whether it would be possible to drive a bolt through the posts and into the concrete from the side instead? (The concrete is about 10 cm thick.)
100 mm is hardly a lot of masonry, I'd be looking for two Rawlbolts at 250mm or wider centres to hold a 70mm square x 900mm high post. A single bolt will mean that the fence might fold flat or break apart if, for example, someone were to fall onto it (and accidents do happen).
Scrit
__________________
Measure twice, cut once - except fingers!
Back to top
 Alert Moderators
hermes
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 14, 2006 8:18 am    Post Subject:
You could bolt the posts to the slabs or the mortar which would stop the bottoms moving around.You could probably brace the fence panels to stop the posts moving sideways, is there a handy wall that you could use to attach a brace higher up the post to stop it moving in and out at the top?
Back to top
 Alert Moderators
Static
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 14, 2006 9:56 am    Post Subject:
You really need to fix the post either side of the gate properly as they will take the most punishment.
__________________
(Any reliance you place upon any advice given will be at your sole risk)
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
post anchoring 2 9640 Sun Mar 24, 2002 7:19 pm
4x4 post anchoring to wood balcony 2 5000 Thu Jul 21, 2005 5:11 pm
Anchoring bookcase to stud partition wall 6 900 Wed Jan 23, 2008 10:50 pm
where to find concrete fence post 4 800 Sun Feb 24, 2008 2:44 pm
Bedding Wooden Fence Post 4 6060 Fri Aug 12, 2005 4:28 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
