DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Baxi boiler ,flame failure
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
spinna
from United Kingdom
PostPosted: Sun May 14, 2006 5:54 pm Reply with quote
we have a baxi 105 HE bolier and the boiler lights up for about 10 seconds then goes off, the flame failure light is on as well icon_sad.gif
can anyone shed some light on why this is happening??
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3437 times
PostPosted: Sun May 14, 2006 8:01 pm Reply with quote
It seems that the pcb is not detecting the flame.
Assuming the flame is actually lighting either the flame detection electrode is not giving the required signal or the PCB is faulty.
A common fault with this model is the gas valve settings need adjustment.
All these are likely to need a competent CORGI engineer.
Tony
Back to top
 Alert Moderators
ollski
from United Kingdom
Thanked: 64 times
PostPosted: Sun May 14, 2006 8:34 pm Reply with quote
Any electrical work been done recently?
Back to top
 Alert Moderators
spinna
from United Kingdom
PostPosted: Tue May 16, 2006 4:36 pm Reply with quote
hi , why do you ask ?
Back to top
 Alert Moderators
ollski
from United Kingdom
Thanked: 64 times
PostPosted: Tue May 16, 2006 4:46 pm Reply with quote
Because reverse polarity in the electrical system will prevent the boiler detecting a flame.
Back to top
 Alert Moderators
poxi
from United Kingdom
Thanked: 43 times
PostPosted: Tue May 16, 2006 6:43 pm Reply with quote
1. Reverse polarity as already stated
2. Does the flame when its on for 10 seconds lift of the burner icon_question.gif
Back to top
 Alert Moderators
Baxi-Remeha
from United Kingdom
Thanked: 88 times
PostPosted: Tue May 16, 2006 8:42 pm Reply with quote
check the top of the condensate trap for water in the resevoir at the top, as this interupts the flame sensing.
or flue fault, flame lifting off burner (as stated by poxi)
or reverse polarity caused by recent electrical work, or been installed by a numpty who is colour blind.........
or gas preasure adjustment, but this is normaly only the minimum gas preasure, so would only cut out on c/h, as it will fire for more than 10 seconds on high flame for hot water.....
or of course it could be the pcb, but my money is on the trap overflowing.....
Back to top
 Alert Moderators
raynos
from United Kingdom
PostPosted: Mon Nov 29, 2010 5:10 pm Reply with quote
Hi I am having the same problem I think... how did you get round this??
http://www.diynot.com/forums/viewtopic.php?p=1815544#1815544
Regards
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Baxi Potterton Main Combi 24 HE Boiler - Flame Failure 22 40140 Wed Feb 27, 2008 8:52 pm
baxi 105 flame failure 9 2460 Sun Nov 19, 2006 8:54 pm
baxi 133 he plus flame failure 19 2220 Thu Dec 24, 2009 9:19 pm
baxi 105e flame failure neon 2 520 Sat Jan 16, 2010 7:41 pm
Baxi 105he flame failure Fault..... 9 1360 Mon Apr 27, 2009 6:40 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
