Long story and probably even longer responses, but here goes...
(am currently on second year of 2330, so am not qualified, but am "sort of" competent!! I also have access to qualifed sparks when necessary, so please no lectures on Part P etc)
Friday afternoon the electric hob tripped the house. I have an MK board with 100mA earth leakage circuit breaker for 7-ways. Oven had been on for a while, but ceramic hob was the breaker. Run on 6mm from 30A breaker(?) thought they were 32 as breakers and 30 as fuses????
Later, having isolated that circuit the electric shower goes, and its on a 32A breaker with 6mm cable. Have since found that previous occupier had cut into this supply and run the power and lights to the loft from it, as well as the switched fused spur to the boiler!!! I have since cut this from the circuit and run the loft and boiler from a fused spur previously used for the immersion heater (that was removed due to a fire that started in the airing cupboard!) YES you can see a pattern emerging here...
On further investigation have found that the only 'safe' circuits seem to be the 5A lighting circuits as the others are all overloaded in one way or another.
I have had cavity wall insulation installed and the cabling runs thru this to the various floors, thus compounding a seriously overloaded circuit.
I am now waiting for a new board and respective MCB's RCD's, with no cooker/hob circuit or electric shower circuit.
THEN....this morning....just turning on the hoover has tripped the house again.
What am I missing here? Is the main switch tripping easier or do I have a leak to earth?
Any advice would be appreciated
Al
(PS sorry about the username, but its a long standing one with an even longer story!)
Al
