DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Shower - hot water plumbing
This topic originated from the How to page called Installing a shower
Click here to return to the page called Installing a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Tigercat
from United Kingdom
PostPosted: Mon May 15, 2006 12:45 pm Reply with quote
I have recently installed a new Mira Event XS power shower into my upstairs bathroom. When in use for the first time each day, there is intermitant \\\'surging\\\' noise as the water feeds through the pump. Happens for a few moments then the full flow is on. I assume air must be getting into the supply pipe.
I have connected the cold water plumbing directly to the cold tank in the attic. So the problem must be from the hot water plumbing/supply - also from the attic. The hot water tank is in the \\\'airing cupboard\\\' at the top of the stairs.
Should I look for an alternative hot water pipe to take the supply from? Which and why?
TIA for any info to resolve this.
Back to top
 Alert Moderators
tincup
from United Kingdom
Thanked: 43 times
PostPosted: Mon May 15, 2006 10:40 pm Reply with quote
Hi
Did you fit a Surrey?York flange to the top of the hot tank icon_question.gif The Surrey/York flange draws from below the airiated heated water.
Alternatively an Essex flange can be used but a hole as to be drilled in the side.
To see for youself go to www.bes.ltd.uk
Hope this helps
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 936 times
PostPosted: Mon May 15, 2006 11:29 pm Reply with quote
That's about the worst place to get it from!
Back to top
 Alert Moderators
Tigercat
from United Kingdom
PostPosted: Tue May 16, 2006 8:16 pm Reply with quote
Thanks for reply. I understand from your suggestion that I need to consider buying a flange. - Then having disconected/cut pipe coming out of hotwater tank, insert the flange and run off my shower connection from there.
It will mean routing the new pipe up into the loft and then across down into the bathroom to the shower unit.
Back to top
 Alert Moderators
diyatbandQ
from United Kingdom
PostPosted: Wed May 17, 2006 5:54 pm Reply with quote
Hi.
I'm just about to install a pump for a power shower. I've bought a York flange which together with the 3/4 inch to 22mm compression adaptor cost about £40. You drain the hot tank, then unscrew the fitting in the top. The York flange fits in it's place and then the original fitting goes into the York flange. The other outlet from the York flange goes to the pump. It says on the pack that it will cope with up to 3 Bar pumps. icon_wink.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Plumbing in a hot water supply to thermostatic mixer shower 3 340 Wed Oct 28, 2009 10:31 am
Shower Tray Logistics: what lies beneath + plumbing acess? 6 700 Sun Aug 24, 2008 5:00 pm
Mixer shower with plastic speedfit plumbing 7 1240 Sun Sep 07, 2008 5:44 pm
question about plumbing part for shower 11 620 Thu Dec 04, 2008 3:36 pm
Need help plumbing in shower! 13 620 Fri Feb 27, 2009 10:51 pm
DIYnot
