dreaded ravenheat combi
15 May 2006
Hull
i dont like these boilers but i hope somebody can help me out,i was called to a ravenheat condensing boiler, and the customerhas complained that the hot water comes on and then goes off when it has reached temperature then it goes off , switch the tap on again after a few minutes and then starts ,then goes off, it also does this when heating only is required, what do you think lol frustrated philby, boardering been peed off with it
I kind of like them, nice and simple
Try the thermisters (both hot water and central heating ones) they should have the values in the MI
Also check out the temperature diff between the primaries
its probably one or the other
I love em'!
Divertors are 30 quid from ABCOT, but a hundred notes more if you use HRPC.
Good boilers, but bad reputation. Never understood why.
David
