Upstair Radiators getting hot when system set to heat Water
25 Apr 2006
Flintshire
Hello and thanks for reading this,
I have a Gravity Fed Gloworm system (not combi) Problem is, lately, when the system is set just to heat the water cylinder, the upstairs rads also get hot.(downstairs remain cold)
I understand that CH systems are complicated and diverse but could someone offer a reason for this?
Regards...Rob
Regards...Rob
It could be that the anti-gravity valve situated on your primary flow ( flow pipe leaving the boiler and going towards your CH ssystem) is knackered if you are sure that this prob was not occuring before.
