DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Time frame of laying parquet
This topic originated from the How to page called Wood block / Parquet floors
Click here to return to the page called Wood block / Parquet floors.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
alice11
from United Kingdom
Thanked: 0 times
PostPosted: Wed May 17, 2006 1:40 pm    Post Subject:
Reply with quote Thanks
Hello,
I'm planning on laying block parquet in about 35sqm but have no idea how long this will take once I've cleaned the blocks (they're reclamied) and prepped the floor (concrete). I think I'll use the non-bitumin adhesive as suggested by Wood-You-Like and the blocks aren't T&G.
The 35sqm is spread between 2 rooms and a small hallway (all on ground level). Any advice on how much time I should put aside, bearing in mind I'm a novice, would be appreciated. As I'm a complete beginner to this and to make it logistically easier I was thinking of not trying to do all 3 rooms in one go, is this practical?
Also, do all parquet floors need a border of blocks around the circumference of the room?
Last question, how do I check the concrete floor is level enough for the parquet before I start laying them?
It sounds like cleaning the bitumin off the blocks before I start will be a big job in itself! Thanks very much for any advice.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Wed May 17, 2006 2:03 pm    Post Subject:
Re: Time frame of laying parquet
Very practical indeed. Depending on the pattern you want to lay it's mostly easier to install the rooms as separate rooms. In doorways you can make a feature of a small border to accentuate the patterns in the rooms even more.
Professionals don't install more than an average of 8 - 10 sq m a day (that's an average calculated including the sanding and finishing of the floor!)
No, it's not needed, but when you have a plunge saw a border will make the installation easier. First install the pattern and go as far as you can towards the walls. Then, after the adhesive has bonded the blocks with the underfloor cut the excess pattern with the plunge saw and install the border. This method is easier than having to calculate and saw last blocks one by one to fit the pattern.
A large straight batten will do the trick. don't get to worried about tiny differences. Small height differences will be 'sanded' away' anyway.
Hope this helps.
__________________
You buy quality, we'll advise. You buy rubbish, we won't!
We're proud members of the BwfA.
Back to top
 Alert Moderators
LionelR
from United Kingdom
Thanked: 0 times
PostPosted: Sun Sep 17, 2006 8:13 pm    Post Subject:
WouldYouLike, I'm planning on installing a wood block floor with border as you suggest, however could you please explain how you lift the cut portions of the blocks after cutting them with a plunge saw? Since the adhesive (Styccobond B92) has set will this also rip out chunks of subfloor? I'm planning on using a latex self-levelling compound first, which will only be a few mm deep and I'm concerned this will fragment.
Also, does the plunge saw leave a clean edge to the wood, or does it not matter about splintering since it all gets sanded and filled in the end?
Many thanks in advance.
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Mon Sep 18, 2006 10:37 am    Post Subject:
Hi LionelR
When applying adhesive to the underfloor with a notch trowel you don't go over the line of your pattern: your last blocks won't have much adhesive on them where they overlap this line i.e. won't damage the udnerfloor much.
The plunge saw we got (Festool) comes with a 'glider' which keeps the saw straight and no, the wood doesn't splinter (normally or you have to have 'splinter-wood'?)
__________________
Back to top
 Alert Moderators
LionelR
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 25, 2006 11:43 am    Post Subject:
Much appreciated, thanks very much for your advice!!
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Laminate Under Door Frame Puzzle 14 2480 Fri Dec 29, 2006 12:46 pm
Cutting Architrave and Door Frame 3 2080 Sun Mar 12, 2006 10:47 am
Tiling on ply floor (frame formed house) 5 1280 Sat Feb 03, 2007 4:26 pm
Laminate Floor tiles - expansion gap around door frame? 3 780 Sat Feb 10, 2007 11:42 pm
cutting door frame to fit wood floor under 3 320 Tue Aug 11, 2009 8:04 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
