Joined: 20 May 2006 Posts: 5 Location: Southampton, United Kingdom Thanked: 0 times
Posted: Sat May 20, 2006 5:08 pm Post Subject:
need help! have no water anywhere!
At first the cold water tap in the kitchen turned without opening the valve. I evaluated that the thread had gone, and with due care prized open the plastic cover, undid the screw and found the offending threadbare attachment.
Under my sink in the cupboard is a tap i understood to be the cold water shut off valve. I shut the water off. I checked in the bathroom that the coldwater was off and it was. I then opened the cold water valve just to check that the water would return..It did not! I assumed I had an airlock and went about searching these pages for solutions.
At this point all the hot water in all my taps worked perfectly. After opening and closing the cold water supply tap about 10 times I now have no hot water or cold water, my toilet system is also non functioning...i claim the prize for most idiotic undertaking of a job i am hopelessly underskilled to carry out but does anyone know what it is that i've done and how to reverse it? any comments greatly appreciated
Joined: 04 Aug 2005 Posts: 5481 Location: Yorkshire, United Kingdom Thanked: 18 times
Posted: Sat May 20, 2006 5:27 pm Post Subject:
The stop cock must be broken. You have to look in the street for one adjacent to your house, prize open the lid. Usually a little square with W on it, only adjacent to your house in the pavement. Lid may need banging with hammer muchly to free it then prize it up. Reach down with long thin arm whiuch has a very strong grip, and feel for a tap, turn it off.
Back into house undo bottom and top compression nuts on stop cock, fit the body of new one you bought before you started reading what I said. Fit new kitchen tap before restoring supply.
If you are as good with street stop cocks as you are with house ones have the no. of the water board handy, they'll come out same day to put right your ham fisted efforts to their tap.
If you can't sort your own stop cock you can't expct wb to also help you foc with that one, it's your responsibility pay a professional.
Posted: Sat May 20, 2006 5:50 pm Post Subject:
Cheers paul for the speedy response, greatly appreciate your comments. I live in a rented apartment and have found the stopcocks for all the flats. I WILL NOT touch the one that deals with my pad (see, i'm learning!)
When i turn on the hot tap i get a blast of hot water then it slows to a trickle and stops.
Does anyone know if I will have to call a plumber, the waterboard or my landlord? I could really do with a flushing toilet that flushes! Am I liable for the repair costs or would the landlord need to front some cash for this one!
Posted: Sat May 20, 2006 5:59 pm Post Subject:
There is a lot of pressre still but no flow, so after the taps have been shut for a while pressure builds up, you open the tap and it gushes but this is not backed up by any flow.
Who is responsible is probably a legal minefield, but if I do something I take responsibility for my actions and fix it or pay for it to be fixed.
Joined: 20 May 2006 Posts: 136 Location: Essex, United Kingdom Thanked: 1 time
Posted: Sat May 20, 2006 6:05 pm Post Subject:
you could freeze just under the stopcock with a freeze kit and then change valve or spin a new body in old valve?Insure no water is running if you want to freeze
Posted: Sat May 20, 2006 7:03 pm Post Subject:
yes, have a storage tank, but not sure what you mean by cyclinder. My flat is all one level, storage tank next to bathroom. I know understand that the lack of all water simply means I've drained the tank.
Joined: 26 Jun 2004 Posts: 24304 Location: London, United Kingdom Thanked: 191 times
Posted: Sat May 20, 2006 11:27 pm Post Subject:
The Landlord is responsible for the maintenance of the plumbing and heating system.
However the tenant is responsible for any damage he causes. The Landlord could argue that an unauthorised attempt by the tenant to repair has caused more damage than had a professional been called.
I have encountered tenants who attempt to repair gas boilers. In some cases where the landlord has ignored the repairs for months thats perhaps understandable.
In my view its the stopcock that has failed closed. Let us know the outcome.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
