DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
UPVC door frame
This topic originated from the How to page called Fitting the new exterior door frame
Click here to return to the page called Fitting the new exterior door frame.
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
  View previous topic :: View next topic
Author Message
Edward Powell
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 21, 2006 1:58 pm    Post Subject:
UPVC door frame
Reply with quote Thanks
During hot weather door appears to expand and catches badly upon the metal fittings in the frame and makes it almost impossible to close. Have you any ideas on how to remedy this situation please?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
big-all
from United Kingdom
Thanked: 24 times
PostPosted: Sun May 21, 2006 4:42 pm    Post Subject:
assuming its on the lock side and specificly towards the top
you can adjust the top hinge often under a removeable plastic cover
mark the hinge and door in relation to each other with a line
you loosen the screws and either move the door by gentle support in the right direction or a allen screw or nut for fine adjustment
move 2mm at a time and tighten at least half the screws when trying for fit
__________________
big all
we are------------------ all still learning
Back to top
 Alert Moderators
bondy
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 21, 2006 8:08 pm    Post Subject:
hi, measure the diagonals of the frame and also the door. if it was fitted correctly, they should be both square. if the doo is longer from the top on the hinge side to the opposite corner, then chances are it has dropped. it will need toe and healing.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
Trim UPVc door frame 4 480 Thu Oct 30, 2008 9:00 pm
Hanging a 2nd hand upvc door and frame 8 440 Wed Nov 19, 2008 9:16 am
Fitting replacement uPVC door and Frame help! 4 1320 Tue Oct 19, 2004 11:26 am
Drilling into UPVC door frame 4 1800 Sun Apr 20, 2008 4:43 pm
Attaching upvc window frames to upvc French door frame. 7 960 Sat Jul 21, 2007 12:35 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
