DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Laying 18mm Oak Floor on concrete floor
This topic originated from the How to page called Wooden flooring
Click here to return to the page called Wooden flooring.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
Mike P3
from United Kingdom
Thanked: 0 times
PostPosted: Sun May 21, 2006 8:04 pm    Post Subject:
Reply with quote Thanks
The concrete floor at present is over laid with vinyl tiles.The flooring supplier states I should remove all the vinyl tiles and glue the floor directly to the concrete, the vinyl tiles are sound and free from damp is there any reason why the wood floor should not be laid directly onto the vinyl tiles
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Sun May 21, 2006 8:51 pm    Post Subject:
Re: Laying 18mm Oak Floor on concrete floor
The first reason that comes to mind is that the manufacturer recommends you don't do it.
Personally, I would call them and ask why, if the tiles are sound, they have to be taken up.
Back to top
 Alert Moderators
FMC
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 22, 2006 6:50 pm    Post Subject:
I would just lay batons ontop of the tiles and then put your flooring on that.Its what i ended up doing as there was no sign of damp.
Back to top
 Alert Moderators
gcol
from United Kingdom
Thanked: 12 times
PostPosted: Mon May 22, 2006 8:34 pm    Post Subject:
I would have thought that it was a no no to lay flooring directly onto concrete. You have to lay a membrane under laminate flooring - I would have thought the same would apply to solid wood flooring too.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Mon May 22, 2006 8:45 pm    Post Subject:
Laminate flooring is designed to float on the substrate. I believe this is at least part of the purpose of the membrane.
Back to top
 Alert Moderators
popey
from United Kingdom
Thanked: 0 times
PostPosted: Tue May 23, 2006 6:09 am    Post Subject:
You can glue hardwood flooring directly to concrete if there is no sign of any moisture, however on most concrete, including anything that been laid less than a couple of years we apply a coat of epoxy resin first to act as a moisture barrier.
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Tue May 23, 2006 10:27 am    Post Subject:
We normally recommend that with vinyl tiles you leave them where they are (because removing them normally ends up with damaged screed/concrete floor). Install the new floor floating and use a combination of DPM and sound-insulation underlayment. (Dpm to prevent 'sweating' of the vinyl tiles reaching the new floor)
__________________
You buy quality, we'll advise. You buy rubbish, we won't!
We're proud members of the BwfA.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
help! laying 18mm 90mm oak flooring on concrete 7 860 Wed Feb 18, 2009 9:33 pm
going rate for laying 18mm oak flooring 2 420 Sun Nov 09, 2008 8:15 pm
18mm Oak Floor on screed - gaps 8 3540 Wed Oct 31, 2007 12:37 pm
How to replace 18mm chipboard floor 3 720 Tue Mar 24, 2009 1:02 pm
18mm x 120mm oak floor 5 1120 Mon Aug 27, 2007 7:15 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
