diyatbandQ
Joined: 03 May 2006 Posts: 18 Location: Yorkshire, United Kingdom Thanked: 0 times
Posted: Tue May 23, 2006 7:10 pm Post Subject: Electrical connection - shower pump |
Hi Everyone,
I have plumbed a power shower pump into my airing cupboard  and now intend wiring it up. It has been suggested to me that I take a spur from a nearby socket to a switched, wall mounted socket and use a 13 amp fused plug.
However, another source  has said that I should take the spur to a fused, switched spur connection box with an LED and wire the pump directly and permanently into this.
Which is correct if either, or is there another, better way?  |
sparkybird
Joined: 19 Jan 2005 Posts: 594 Location: United Kingdom Thanked: 2 times
Posted: Tue May 23, 2006 7:18 pm Post Subject: |
Is the airing cupboard in the bathroom? You're not allowed to have sockets/plugs/switches in the bathroom, so suggest the fused spur/direct wired (not switched) is the best option. Also check the pump instructions for the size of fuse, it might be less than 13A
Hope this is helpful
SB |
diyatbandQ
Posted: Tue May 23, 2006 10:42 pm Post Subject: pump connection |
Very helpful thanks.
The airing cupboard is across on the other side of the landing to the bathroom, adjoining bedroom, so no problems like that.
So presume wall socket ok. 3 pin plugs would make it easy to replace pumps if necessary. But will install fused spur if thought best practice.
Instructions silent on fuse, but good point.
Would a 5 or 3 amp fuse suffice? Being a pump, it may have a start up surge and then settle to a lower current. I suppose I could simply put in the lowest that doesn't blow though.
Many thanks once again  |
Plug
Joined: 23 May 2006 Posts: 24 Location: Sheffield, United Kingdom Thanked: 0 times
Posted: Tue May 23, 2006 10:52 pm Post Subject: |
It's tricky (to say the least) for anyone else to guess the size of fuse that you need. My recommendation would be to consult the documentation that came with the pump. |
diyatbandQ
Posted: Wed May 24, 2006 9:34 am Post Subject: thanks |
good point. Thanks for ideas.  I'll phone manufactureres (spellcheck?) and ask them for definitive answer. |
