the radiators get piping hot but the water comes out cold, the situation has got worse as for a couple of weeks we had to put radiators on to get hot water and nothing happens when we set equipment just for water.
house was built in 1989, under the stairs it is a baxi with a UP2 Dual Channel prgrammer, c/heat blr solo 2 PF 40. and upstairs in the airing cupboard is an M.D indirect cylinder, unishare with port a and b on it, a Euramo Gold (i think its a pump it get very hot and it has a black box joined underneath with electrical wire going to switch).
Either the cylinder stat has failed ( rare if not touched ) or the motor valve has failed. It may have a lever to hand move it until you can change it.
