norfolknhope
Joined: 26 May 2006 Posts: 3 Location: Berkshire, United Kingdom Thanked: 0 times
Pens
Joined: 17 Jan 2006 Posts: 2433 Location: Kent, United Kingdom Thanked: 0 times
Posted: Fri May 26, 2006 4:19 pm Post Subject: |
The wiring diagram here shows the switchwire to the light connected to the ~ terminal in the master, the S in the master connected to the S in the slave and the live feed connected to the live terminal in both the master & slave.
You may need a meter to establish which cable is which if there not marked. |
norfolknhope
Posted: Fri May 26, 2006 4:23 pm Post Subject: |
Thanks for the info, it's the same wiring diagram that came with the units which means nothing to me, I just wondered if anyone could tell me from my discription what wires to put where.
Thanks  |
Pens
Posted: Fri May 26, 2006 4:34 pm Post Subject: |
I just told you which wires to put where, my problem is from your description I don't know which of your existing wires is which.
If you can post a picture of your existing connection that would help |
norfolknhope
