faith
Joined: 26 May 2006 Posts: 3 Location: United Kingdom Thanked: 0 times
Posted: Fri May 26, 2006 9:51 pm Post Subject: different loft insulation types |
I need help. I am trying to understand how loft insulation generally works. I understand that the building regulation has a requirment of reaching the U-value of 0.16w/m2k, am I right? I would like to ask how is loft insulation usually installed and how much thickness of different insulating materials i.e. flax and hemp fibre,sheep wool needed to achieve the same U-value as mineral wool or fibre glass? PLEASE HELP.
thank you. |
JohnD
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Fri May 26, 2006 10:55 pm Post Subject: |
Out of interest, we've had a few people thinking about sheeps wool as loft insulation. Where did the idea come from? |
faith
Posted: Sat May 27, 2006 12:24 am Post Subject: |
not sure. i was told to have many other alternatives. anyone has any idea how much thickness of different insulating materials to achieve the building regulation requirements of u-values? |
Deluks
Joined: 23 Feb 2005 Posts: 3612 Location: Surrey, United Kingdom Thanked: 24 times
faith
Posted: Wed May 31, 2006 9:43 am Post Subject: urgent |
thank you for the above advice.
when the K-value for a certain insulation material, say k-value, thermal conductivity for rockwool is 0.044w/mk which it says on the webpage, does it mean to all kind of thickness? or different thickness will have different k values? how can i calculate between and over joist thickness? i just know i need 300mm between joists?
sorry, im still confused |
